Latest: sparrowdclxvi
Overall: 17139
Online Now [88]:
Visitors: 87
Today: 21536
Total: 113261876
Forums › The Car › Solved 206 Problems › Manifold rattle on GTi RESOLVED
PostPosted: Thu Mar 11, 2010 6:36 am Up
I've heard about issues with a rattling manifold on the GTi but I'm not clear on what the problem is.
I did a few searches on here and google and this is the best I came up with, Link.
Its annoying as it only started the other day. 30mph or cruising its fine but put my foot down a bit and its tap-tap-tap-tap....
So what is causing it and how do / how much is a fix?
Laughing
I answered my own question, in the article was this link
Still any idea on cost?
Kratos
PostPosted: Thu Mar 11, 2010 6:52 am Up
take it to a half decent garage and get it welded, make sure it is that though
Previously 206 GTI SP.
Now SUBARU IMPREZA 2.0 AWD
206ed
PostPosted: Thu Mar 11, 2010 7:15 am Up
i have manifold rattle but mine does it at exactly 2500 rpm and not if i put foot down :S
also its more of a buzzing noise than a tap tap tap so i think you may have another problem bud Sad
206 gti 138
Team: no sub
Team: no back seats Wink
Big_Rich180
PostPosted: Thu Mar 11, 2010 7:43 am Up
I have the same problem, i was told by someone who is very experienced with gti 180's that it is the heat shield above the manifold rattling on the body work. You can just see the top of it if you look down the back of the engine.
PM gti180boy for more info.
Hope this helps.
PostPosted: Thu Mar 11, 2010 7:48 am Up
Hope this helps.
I know of the heat shield issue, but this is different.
Big_Rich180
PostPosted: Thu Mar 11, 2010 7:51 am Up
Still, PM gti180boy, he is experienced with this stuff.
wooders_09
PostPosted: Thu Mar 11, 2010 7:59 am Up
Got exactly the same problem with mine, but the exhaust makes it hard to hear it. Only really audible around 2300-3000rpm then it sort of goes away. But it is like a faint tapping noise
Firedance GTI 138, Tivoli Blue 1.9 D
Indigo_GTI
PostPosted: Thu Mar 11, 2010 2:54 pm Up
not the greatest of pics but i got mine done. it wasnt rattling but heard it was a common problem and while the mani is off best to get it sorted
oh yeh and cost, nothing for me as i know someone who works in a fab shop but its a 5 min job and would cost you £10 max to get done, only issue is having the mani in front of you in the first place
wooders_09
PostPosted: Thu Mar 11, 2010 4:59 pm Up
That was my main problem when the next exhaust was fitted- it is really hard to get to whilst on the car: read: nigh on impossible: and its a b***h to remove from the car too.
I should imagine with a bit of patience it can be done on the car but it is pretty tight up there
ashymcfc
PostPosted: Thu Mar 11, 2010 5:31 pm Up
had mine done last year, bloke who did it seen where needed to be welded and said it wont make a diffrence but it did, not a noise now
206GTI 2000 138BHP
Porra46
PostPosted: Fri Mar 12, 2010 1:01 am Up
GTi180s don't have the manifold rattle. They have the manifold heat shield rattle. The GTi138 has the manifold rattle internally. The 180s manifold is different. It's a 4 into 1, unlike the 138.
2010 Aluminium silver Peugeot 207 GTi
Username
PostPosted: Fri Mar 12, 2010 4:46 am Up
I also have the same buzzing noise on my 138 as soon as i hit 3000rpm.
It's annoying, but i can live with it for now. She is due her yearly service at the end of the month, so hopefuly i will get it sorted then.
206 GTi With Full SP Pack.
PostPosted: Tue Mar 16, 2010 4:18 am Up
Problem solved!
The olive clamp that holds the Cat to the manifold was only half on!
Replaced it with a new one and is now silent!
crot10
PostPosted: Tue Apr 06, 2010 1:48 pm Up
I have a 206 GTI 138bhp it has what i thought sounded like a tappet rattle when under load but not when you just rev the engine.
I thought it might be low on oil because i had a astra 2.2SRI that was a company car that i regularly let run low on oil and it started to tap. It sounds similar to that but its now low on oil at all.
Cam belt is being changed this week so im thinking of getting this done at the same time do you think thats what the noise is?
Don\'t fooled by others
View user's profile AIM Address Yahoo Messenger
Milemuncher
PostPosted: Thu May 13, 2010 2:39 pm Up
Have exactly the same issue, most noticeable around 2800-3000rpm, or when accelerating hard. Due a service in the next few months so will mention it to my mate who does it.
52 plate 206 GTi China Blue
