Posted: Mon Oct 03, 2011 5:24 am |
is so how do u do it as my pedel is higher now and now doin more miles in car it a pain can i make it sit lower down so nicer to drive with?
Posted: Mon Oct 03, 2011 7:19 am |
I know exactly what you mean mate.
All 206 have an auto-adjusting clutch cable mechanism, so you cannot adjust it as such.
I recently replaced the whole clutch set and cable due to it being very stiff and having a sensitive
left knee. Best money I've ever spent on the pug..
(The springs go stiff over time due to metal fatigue.)
However some models have a hydraulic clutch system which I know nothing about.
Posted: Mon Oct 03, 2011 7:33 am |
Just change the clutch cable, only about £20. If it makes a difference then brilliant but if not then it doesnt matter.
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport | |
Howey wrote: |
Just change the clutch cable, only about £20. If it makes a difference then brilliant but if not then it doesnt matter. |
+1
Posted: Mon Oct 03, 2011 7:54 am |
Will be a hydraulic clutch on the OP's 206
Have fun trying to locate that non existent clutch cable
Posted: Mon Oct 03, 2011 8:41 am |
V9977 wrote: |
However some models have a hydraulic clutch system which I know nothing about. |
MrBSI wrote: |
Have fun trying to locate that non existent clutch cable |
Any info?
Posted: Mon Oct 03, 2011 9:17 am |
how did you get the pedal higher?
not sure ive ever seen a way to adjust it, although my best guess would be on the master cylinders somewhere.
Posted: Mon Oct 03, 2011 12:33 pm |
it will be hydraulic which has no adjustment. if the pedal is getting higher then i would guess at the clutch starting to wear out
