Posted: Wed Oct 05, 2011 1:55 pm |
Hello everybody,
Well its my first peugeot 206 and its a 1.4 LX V reg. Well today i was just fiddling around with the clock dash. And i decided to remove the dash (i was bored and trying to waste some time waiting for somebody ) anyway i removed the dashboard of the clock and hazard light. however i didnt remove any wiring. I put the dash cover back on and it all clicked in place. when i started the car, the clock light didnt come on. Ive searched around google etc but i havent found any useful advice.
Could somebody please help me?
Thank you in advance.
| Pug 206 1.4 SW - July 2013 - Present
Peugeot 206 1.4 HDI - Oct 2013 - Present
BMW E30 - April 2013 - RIP | |
Posted: Wed Oct 05, 2011 1:57 pm |
may have simply disturbed the bulb somehow, take the top off again, with the ignition on wiggle bulb in back see if it flick on or anything.
a simple test to know if its the bulb or/and display not working is to shine a torch on the screen, if you see the time slightly then the bulb is not working.
Posted: Wed Oct 05, 2011 1:58 pm |
to hazzard a guess id say you disconnected somthing by mistake undo and check connections or you broke something and need new display but id do it loose before connecting and see if it flicks on when having a wiggle
| 206 HDi 2.0 XSi. Du7ch My Garage
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former.
- Albert Einstein (1879-1955) | |
Posted: Wed Oct 05, 2011 2:04 pm |
Oh no not a new display!! how much would a new display cost? il have a look tomro in the morning...would the bulbs need replacing?
Posted: Wed Oct 05, 2011 2:07 pm |
Posted: Wed Oct 05, 2011 2:08 pm |
dsiingh wrote: |
Oh no not a new display!! how much would a new display cost? il have a look tomro in the morning...would the bulbs need replacing? |
probably only about a tenner i would say at most, i would say its just the bulbs like said before tho
i take it being lx its just a single clock display like below?...........
Posted: Wed Oct 05, 2011 2:25 pm |
Yup its a single clock display..however i dont hve the fancy edition of a central lcking button.
Where would i be able to get the bulbs frm any ideas ?
Posted: Wed Oct 05, 2011 2:44 pm |
I got my bulb from a motor spares store for 27p when mine went
Where in west midlands are you?
| Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport | |
Posted: Wed Oct 05, 2011 2:51 pm |
im in oldbury, near dudley, smethwick, wolverhampton, handsworth
which bulbs would i need? do they have a special part number? and is there a guide on how to change the bulb?
Thanks again everyone
Posted: Wed Oct 05, 2011 3:53 pm |
pull the cover back off, undo the two torx screws holding the clock in, pull it forward, twist the bulb until it comes out, twist the new bulb in and reassemble.
Posted: Thu Oct 06, 2011 2:47 pm |
Does the torx screwdriver have to be a certain size? i dont have these so ill have to go buy them...
also any ideas of where i could get this bulb from?
Posted: Thu Oct 06, 2011 3:31 pm |
I'm in great Barr so about 5 mins on the m5/m6
Yeah you'll need a torx screw set if owning a 206, all interior parts are held on by them basically
Posted: Sat Oct 08, 2011 1:58 pm |
Problem Solved!
Torx screwdriver £2.99
LED Bulb £1
thinking about it the led bulb was a rip off! but the time i wasnt paying much attention.
It took me around 15minutes but in the end i got it. I was scared about breaking the circuitboard. But i pulled through and behold there is light with the clock.
Thank you to everyone much appreciated.
