Latest: lio94
Overall: 17181
Online Now [112]:
Visitors: 111
Today: 52891
Total: 140997410
Forums › The Car › 206 Problems › 206cc Oil pressure insufficient
silverfox1264
PostPosted: Sun Oct 09, 2011 7:56 am Up
Hi,
A mate has a 206cc Allure 1600cc , which is showing Oil pressure insufficient when the car is started also the mpg is around 30ish, not sure if this is linked.
When the Oil pressure insufficient is displayed you also get the oil light on the dash also the STOP flashes & you get the warning bleeps.
After you rev the car to 2000 rpm & over all the dash is back to normal.
When driving the car all seems to be ok.
Any ideas on what it might be.
im new
PostPosted: Sun Oct 09, 2011 7:58 am Up
Actually checked the oil?
silverfox1264
PostPosted: Sun Oct 09, 2011 8:01 am Up
Yes the oil dip stick is showing full.
He has not had the car long, & had a cambelt change & full service about 2/3 months ago.
im new
PostPosted: Sun Oct 09, 2011 8:05 am Up
Checked the sensor?
also when was the last time it was serviced?
silverfox1264
PostPosted: Sun Oct 09, 2011 8:07 am Up
That's what I thought it might be, but I have no idea were it would be in the engine or how we would check it if it was found.
im new
PostPosted: Sun Oct 09, 2011 8:09 am Up
Non genuine oil filter can also cause this.
Peugeot / Citroen OR Purflux oil filter only!
silverfox1264
PostPosted: Sun Oct 09, 2011 8:20 am Up
Ok we will go have a look at the oil filter when I get a chance as im at work.
Thanks for the help.
im new
silverfox1264
PostPosted: Sun Oct 09, 2011 9:34 am Up
Ok just looked, & the oil filter is a Purflux.
Any other ideas what else it could be?
im new
greg.mitchell350
PostPosted: Sun Oct 09, 2011 9:41 am Up
no oil leaks at all obviously? do you have a receipt saying the type and make of oil used?
206 enthusiast
silverfox1264
PostPosted: Sun Oct 09, 2011 9:58 am Up
No oil leaks can be seen.
The oil that he says he used was Wilkinson's Laughing wilko semi synthetic 15w/40 which he said on the bottle is good for most cars. Shocked
im new
PostPosted: Sun Oct 09, 2011 10:03 am Up
oh dear
greg.mitchell350
PostPosted: Sun Oct 09, 2011 10:10 am Up
so the actual oil specified by peugeot wasn't used?
206 enthusiast
PostPosted: Sun Oct 09, 2011 10:11 am Up
not even the right grade, let alone brand Laughing
PostPosted: Sun Oct 09, 2011 10:17 am Up
recommanded oil is listed in the user manual
silverfox1264
PostPosted: Sun Oct 09, 2011 10:21 am Up
He didn't have a manual when he brought the car.
I did laugh when he told me Laughing
But he had the problem before filling up the oil so it's not the cause of the problem.
im new
