Online Now [1094]:
Visitors: 1093
Today: 153701
Total: 151004358
Forums › The Car › 206 Problems › Removing Interior Map Light
Spark
PostPosted: Tue Oct 11, 2011 9:51 pm Up
Hey guys,
I've done a forum search for this but the only thing that came close was to remove the lens from the side with a screwdriver, there's no way a screwdriver will fit in the space beside the lens on mine!
There's a moth INSIDE my overhead reading light and I don't know how to get the cover off. It seems the whole plastic housing is hinged at the back so I tried to lever it from the front but it seems to need a LOT of levering and before I end up snapping it off altogether, just wanted to hear from you guys because I know someone here will know Smile
If it makes any difference, its a 2004 model
Any help is appreciated! Thanks for reading Smile
mtempsch
PostPosted: Wed Oct 12, 2011 2:02 am Up
Spark wrote:
Hey guys,
It is pretty tight, so either get a smaller screwdriver or use a thinner tool of a different kind, maybe a kitchen knife.
Inserting it about a mm or so (on the right hand side [might work from the left too, but the right is what I used]) and levering it out IS how to do it, both for the main light and the map reading light.
Silvermetallic 2004 206 RC
LiamGTi180
PostPosted: Wed Oct 12, 2011 3:13 am Up
It does come out eventually. Just try to be gentle but firm. I used right hand side aswell and that seemed to work
Spark
PostPosted: Wed Oct 12, 2011 7:18 am Up
Thanks heaps guys, I'll definitely give it a shot and let you know how it goes! Smile
Will the next word you say be \"no\"?
