fatboyslim wrote: |
gazza82 wrote: |
Don't bother with rain-x .. it scrapes off in stripes then you have to clean screen with a heavy-duty, mildly abrasive cleaner to get the rest off.
Used it for week then chucked it in the bin.
Better to have good wipers!
Haven't tried Bosch on the 206, but had them on the Alfa for years .. 21/21 as Lee says. Clio has Valeo's I think. They've been on for about 4 years, still working well but don't look as good. wiperblades.co.uk might do a discount for us .... otherwise try a google search and it might throw up another discount code (I think I used a Scooby one once ) |
Rain-X is pretty good,you need to have a really clean windscreen before applying it though,it's also a good idea to give your wipers a clean too |
Never had a problem with Rain-x. I use it on all the glass, side windows get 2 coats, windscreen 4 just to make sure that it's filled all the pits. Get to 20mph and the water is running off. 60mph behind a truck on the motorway in heavy rain, and the vision is perfect with no wipers on. My wipers only really get used when I first set off and when I use the washers which also has Rain-x screen wash in the washer bottle.
If you don't apply it correctly you can get a lot of smears which can be annoying with any kind of light hitting it, but that's the same for any type of product you put on your screen.
