Latest: Andyblue64
Overall: 17123
Online Now [448]:
Visitors: 447
Today: 38262
Total: 98309861
Forums › The Car › 206 Problems › New rear shock absorbers
jaypug206
PostPosted: Fri Oct 14, 2011 4:17 am Up
Hi,
I bought some new rear shock absorbers, sachs one's from euro car parts.
The old oem rear bush on the right side was really knackered.
Anyways got the garage to fit it yesterday, car feels like its got more grip on the road and feels more firmer on the road. But its rattling over tiny little bumps and making more noise then the old one's.
Anyone got ideas why this might happen? Or do I need to let them wear in with a bit of mileage?
I did not prime these either as I never knew this, but the mechanic I know, he didn't either but I'm sure if your meant to he would of as he's a good reliable honest mechanic.
PostPosted: Fri Oct 14, 2011 5:57 am Up
Are the bolts tight?
jaypug206
PostPosted: Fri Oct 14, 2011 8:28 am Up
I didnt do it but I will have a look thanks
PostPosted: Fri Oct 14, 2011 8:29 am Up
Should have primed them.
Run them in. (let them settle)
