Posted: Sun Oct 16, 2011 3:40 am |
Looking to upgrade my front fog light bulbs which gives out good output for when they are needed to be used, have found this thread
www.206info.co.uk/Foru...17270.html
but just curious as to if there are any other bulbs and what fitment the bulbs need to be
Posted: Sun Oct 16, 2011 3:49 am |
fog is H1 and LED bulb is useless in fog so as main light
Posted: Sun Oct 16, 2011 3:52 am |
| Seabook wrote: |
| fog is H1 and LED bulb is useless in fog so as main light |
any particular bulb you would recommend mate which isn't LED?
Posted: Sun Oct 16, 2011 3:56 am |
I have Halfords all weather ones in mine. They are a kind of yellowish purple look and work very well in fog.
I wouldnt really spend a lot on bulbs as you dont use them that often.
Posted: Sun Oct 16, 2011 4:02 am |
don't plan on spending alot on them, just thought before I fit my masked foglights that I would change the bulbs
Posted: Sun Oct 16, 2011 4:08 am |
i got some lucas all weather bulb, but they are quite yellowish
Posted: Sun Oct 16, 2011 4:52 am |
| Mikey2uk wrote: |
I wouldnt really spend a lot on bulbs as you dont use them that often. |
Plenty of idiots out there do as they think they look cool driving around with them on
Posted: Sun Oct 16, 2011 5:25 am |
| MrBSI wrote: |
| Mikey2uk wrote: |
Plenty of idiots out there do as they think they look cool driving around with them on  |
When I had the 530d I passed someone at night. Flashed my fog lights on/off at them & they turned them off. I think I was mistaken for a police officer a few times
Posted: Sun Oct 16, 2011 6:47 am |
I don't see why anybody would want to use their front fog lights ever.
