Posted: Tue Oct 11, 2011 3:26 pm |
evening people, bought my first 206 last night owned for approx 12 hours before the usual french build quality started to show lol, gear linkage dropped off on motorway (brilliant getting home with only 3rd, 4th and 5th gears selectable) sorted that easy enough but now the monster sunroof has decided to be a t**t, fuse is fine and can hear motor running ok but nothing is doing with the actual roof. ive managed to get it closed and water tight (ish) but where the hell do i start trying to sort this??? ANY pointers will be greatly appreciated
Posted: Tue Oct 11, 2011 3:38 pm |
there will probably be some sort of pulley system to open and close it, maybe the belt/cables come off or snapped
Posted: Tue Oct 11, 2011 3:53 pm |
i was thinking the same thing mate my main problem is how the hell do i find out without removing head lining
Posted: Tue Oct 11, 2011 3:58 pm |
what happens if you hold down the open/shut switch? does it run for ever or does it go so far before you here a jamming noise,
i think it may run the same mechansim as electric window, the motor is definitely the same anyway!
Posted: Tue Oct 11, 2011 4:44 pm |
probably the cable is snapped
Posted: Tue Oct 11, 2011 4:54 pm |
I hear jamming/juddering/grinding noise after so long, how will i know/find out if its a snapped cable??? i cant see a way of working on it ive had the courtesy light plate out and alls thats there is the motor
Posted: Tue Oct 11, 2011 5:12 pm |
Posted: Wed Oct 12, 2011 1:17 am |
Nice one ghosty, bought and paid for!!!
next problem is fitting lol
Posted: Sun Oct 16, 2011 10:11 am |
shame your to far up north for me otherwise id of had a go at it for you (used to pull my 306 cabriolet roof apart all the time).
