Latest: dreyfalon
Overall: 17121
Online Now [516]:
Visitors: 515
Today: 111361
Total: 97515012
Forums › The Car › 206 Problems › Overheating 1.6 HDi GTi
scottwyatt68
PostPosted: Thu Oct 20, 2011 2:51 am Up
Morning All,
My wife has a 1.6 HDi GTi - its a great car and she loves it, but we're having a problem with overheating. It seems to happen more when reused shortly after another run. The cooling fan kicks in on switching the engine off, which is fine, but this is draining the battery and causing starting problems.
Its had a new battery and coolant levels are fine. Also been serviced, so it has new oil at correct level. Any ideas?
Thanks,
Scott
Scott Wyatt
colganraz
PostPosted: Thu Oct 20, 2011 6:20 am Up
you sure its not just a broken thermostat? check that your radiator aint clogged full of crap too...
other than this all I can say is make sure there's no leaks with coolant etc.
worst comes to worst to it to a qualified mechanic Smile
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
Lecktorious
PostPosted: Thu Oct 20, 2011 6:25 am Up
Trade Rating: +59
scottwyatt68 wrote:
Morning All,
Thanks,
Scott
I think your DPF may be regenerating and that's whats causing the fans to kick in. Fans should go off with the ignition though.
'98 Nile Blue 306 GTi 6
PostPosted: Thu Oct 20, 2011 9:29 am Up
scottwyatt68 wrote:
Morning All,
Thanks,
Scott
Cooling fan running when ignition turned off means the FAP system is trying to do a regen, its designed to do that.
The cooling fan should switch off after a maximum of 15 minutes.
scottwyatt68
PostPosted: Thu Oct 20, 2011 11:33 am Up
Thanks all. I have a feeling it might be radiator. Fan stays on when ignition is off and thats what's draining the battery. She does short runs every day with occasional distance, so not great for battery, but on a long run the temp creeps up past 90 degrees and gets hotter as it goes faster, so definitely something in the cooling, just don't know how best to sort!
Scott Wyatt
PostPosted: Thu Oct 20, 2011 11:50 am Up
Short runs are the worst thing ever for the 1.6HDi
My advice, sell the car and get something more suitable for your needs.
Lecktorious
PostPosted: Thu Oct 20, 2011 1:23 pm Up
Trade Rating: +59
My advice, sell the car and get something that won't rape your wallet.
EFA.
PostPosted: Thu Oct 20, 2011 2:19 pm Up
Its trying to do a regen as it has a FAP / DPF fitted.
Which temp gauge are you looking at?
Water temp is at bottom of rev counter on the 5 dial cluster
The temp gauge on the right is for the OIL temp
scottwyatt68
PostPosted: Thu Oct 20, 2011 11:53 pm Up
MrBSI, I'm looking at oil temp, although both rise, I can get water temp down by putting heater on. The real issue is why it gets so hot on everyday use when most cars I know sit static at operating temp and don't move unless there's a problem. I didn't really want to get into changing everything to find out what it is by a process of elimination, but looks like I might have to, so I'll start with a rad flush. Thanks.
Scott Wyatt
Lecktorious
PostPosted: Fri Oct 21, 2011 1:03 am Up
Trade Rating: +59
Laughing
Have you not paid any attention to what MrBSI has said? Its your DIESEL PARTICULATE FILTER that is trying to regenerate itself and that is why your oil temperature is rising. It has nothing to do with the radiator.
You are doing too many short low speed journeys causing the DPF to become blocked. Go and take the car for an hours drive up the motorway, high gear, low revs and use as much electrical equipment as you can.
PostPosted: Fri Oct 21, 2011 8:09 am Up
Awaits the BEEP BEEP BEEP
ANTI POLLUTION FAULT
UNBLOCK DIESEL FILTER
Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing Rolling On The Floor Laughing
Alex90
PostPosted: Fri Oct 21, 2011 8:32 am Up
or u can just give me the keys i can make it run like new again:P
DIESEL POWER!!!
marc206
PostPosted: Fri Oct 21, 2011 3:28 pm Up
there was something about that disel filter on watchdog. gets clogged up with all the crap if you don't go fast enough. they did say take it out for 30 mins at above 50 should clean it, otherwise it'll cost you an arm and a leg to get it fixed everytime.
