Posted: Wed Aug 10, 2011 7:50 am |
Hi everyone,
I'm having problems with my 206, it is a 2004 206 1.4 S Automatic.
It sometimes (less then half the time) when starting the car it revs all the way up to 2000 rpm's then drops to 100 and cuts off. Sometimes it won't cut off and idle at roughly 1000 rpm's and it will be fine.
If I restart the car it be fine and rev up to the normal 1200 rpm's and stay idle around the 900/1000 rpm's.
It's never stalled while driving and braking. Only seems to happen when I start the car.
Any help or advice would be helpful.
Posted: Wed Aug 10, 2011 7:52 am |
coil pack , battery, spark plugs ,idle control vavle
Posted: Wed Aug 10, 2011 7:53 am |
just a few suggestions
Posted: Wed Aug 10, 2011 7:56 am |
Idle Control Valve needs a clean before anything else.
idle control valves a good place to start i would say
Posted: Wed Aug 10, 2011 8:06 am |
Would I be able to clean the Idle Control Valve myself?
Posted: Wed Aug 10, 2011 9:16 am |
Easy. There is a how-to on the forum for it.
Posted: Wed Aug 10, 2011 9:21 am |
Cheers for your help!
Posted: Sun Aug 28, 2011 10:32 am |
I cleaned the Idle Control Valve so we'll see how I get on and I will post back.
Posted: Mon Aug 29, 2011 4:36 am |
My car now idles at 800-900rpm in park and drive, etc.
Could you tell me ASH if yours is the same please?
Posted: Sun Sep 11, 2011 12:48 pm |
It has been 2 weeks now and the car has not stalled (touch wood)
Posted: Tue Oct 18, 2011 7:22 am |
UPDATE:
The car does rev up high again, doesnt always stall but nearly does.
I've noticed it pretty much does it all the time when it is really windy.
Any advice appreciated, cheers.
