Online Now [76]:
Visitors: 75
Today: 17004
Total: 143085501
Forums › The Car › Solved 206 Problems › High temperature stalling/idle flicker
panzer360gti
PostPosted: Mon Oct 24, 2011 2:50 pm Up
Slowly getting problems again with this damned 206 GTI
As soon as engine temp hits 90 and above the idle startsfailing, and has often completely died/stalled, I'm thinking of getting a new ICV, what do you reckon~?
Peugeot 206 GTI 137 2.0
colganraz
PostPosted: Mon Oct 24, 2011 3:20 pm Up
mines done a similar thing 3x the past 2 days... but when switching on the engine, sorry cant help but i will be watching this thread
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
panzer360gti
PostPosted: Tue Oct 25, 2011 2:21 am Up
Ive cleaned the throttle body, tightened up all intake pipes, new air intake temp sensor, allsorts, still get this problem at high temp though!
kit325
PostPosted: Wed Oct 26, 2011 12:14 pm Up
Normally temperature will be around or below 90 mark, even u stuck in traffic.
Check for faulty thermalstat, cooling lvl. If temperature only rinse up when stuck in traffic, check the radiator fan. It should be working when temperature hit above 90.
kit
panzer360gti
PostPosted: Wed Oct 26, 2011 1:30 pm Up
Fan always kicks in around 92, 93, car doesnt particularly overheat, it just stalls or threatens to stall when above 90.
panzer360gti
PostPosted: Sat Oct 29, 2011 1:55 am Up
Well, I may have found the cure for this, touch wood!
Changed my thermostat for a new one, and flushed the whole cooling system, replaced the coolant, and gave the throttle body and ICV a clean, tightened up all the intake pipe/filter housing etc.
Took the car for a run last night and noticed a massive change, in that I sat outside the takeaway with the engine running for ten minutes, and it never went above 90!
Didnt even see the radiator fan kick in, now I know it was cold last night but my car would still have gone up above 90 anyway!
The lumpy idle stopped, and it never looked like stalling.
Will update on this after today, got some driving around to do, after Ive re-seated my damned exhaust which is catching on the heat shield!
