Latest: heikkisj
Overall: 17126
Online Now [73]:
Visitors: 72
Today: 9051
Total: 100318452
Forums › The Car › 206 Problems › climate control heater unit diferances
john206gti
PostPosted: Thu Nov 03, 2011 12:15 pm Up
Ive recently brought my brothers gti 138.
it has a few little bits need sorting but the main one is the heater motor just does what it wants when it want,
I now its the blower motor that needs changing, but is there differences between the climate control ones or will any fit and work?
need it sorting before it gets any colder on the mornings or it will take ages to demist the windows
cheers john
2001 moonstone gti, gt bumpers, gen2 k&n induction kit, lightened flywheel, lowered 35mm,
PostPosted: Thu Nov 03, 2011 1:41 pm Up
Climate control fans are different to all other fans.
paul_c
PostPosted: Thu Nov 03, 2011 2:53 pm Up
john206gti wrote:
.... the heater motor just does what it wants when it want.......
Are you sure its broken? This is what the climate control fan does - it varies according to the air temperature etc to control the ventilation as desired. If its noisy, its noisy though - so needs lubricating or replacement.
john206gti
PostPosted: Thu Nov 03, 2011 5:21 pm Up
yes its defiantly broken. when not in auto if i press the + or - it doesn't do anything. then it will just come on and go off all of a sudden.
i meant are all the climate control blowers the same. gti, cc, hdi, xsi ect
ronnie
PostPosted: Mon Nov 07, 2011 5:47 pm Up
Take the blower motor unit off
Test the motor on its own......+ve and -ve to the motor and it should work
The aluminium bit with the pegs is a resistor and it might be only this part that needs changed.
I did mine earlier in the month........£40 for a brand new resistor from e-bay
It is for a 307 but fits the 206 motor
Works a treat
Hope this helps
Ronnie
ronnie
john206gti
PostPosted: Wed Nov 09, 2011 6:09 pm Up
i replaced the full blower the weekend/
i have put the old one to one side as i thought it could be just the resister
thanks anyway
john
