Forums › The Car › 206 Talk › anti roll bar bushes |
Posted: Tue Nov 01, 2011 1:37 pm |
Edward wrote: |
Tam80 wrote: |
would they not last longer ?
wear better ? |
Standard bushes hardly wear quickly. |
so what bushes would i be better trying to get in poly then ?
Posted: Tue Nov 01, 2011 2:10 pm |
i think Ed is telling you, you dont need polybushes as there is no advantage to using them over OE arb bushes.
thing is, if you want them, get them
Posted: Tue Nov 01, 2011 2:42 pm |
Mr_Cellexe wrote: |
thing is, if you want them, get them |
had my fair share of cars..fed up spending loadsa dough then getting rid (bored)
just want everything done on this and then start some modding...just ordered front bilsyeins from the bay...ready to order the rear shortly...also got lemforder drop links from ecp...that leaves me needing wish-bones and whatever bushes i am needing for front/rear
how do i find out the part number for the hose from the expansion tank to the heater matrix (hose that splits into 2) ?
cheers again
Posted: Tue Nov 01, 2011 3:07 pm |
You want one of these?
Posted: Tue Nov 01, 2011 4:20 pm |
Posted: Thu Nov 03, 2011 2:03 pm |
any idea how much this hose is from stealers ?
part number ?
cheers guys
Posted: Thu Nov 03, 2011 2:39 pm |
They are £32 from the dealer. Part number is 6464XN for the type that slides onto the coolant reservoir and is held in place with a clip. You can have mine delivered for £20. It spent about a month on the car...a car that didn't even get used much at all in that time. Therefore it's still in brand new condition.
