Online Now [282]:
Visitors: 281
Today: 3698
Total: 142272223
Forums › The Car › 206 Problems › Refitting the original head unit
Robj10
PostPosted: Tue Nov 01, 2011 3:16 am Up
Hi everyone,
Before I start, I best just say that I dont have much knowledge on this subject.
So yeah, 2 years ago, I bought myself a 206 and took it straight down the local car audio shop and got a new head unit and speakers installed. I also had installed whatever it is that allows you to still use the volume paddles on the steering wheel (not sure whether this was some sort of wire or a piece of equipment or whatever?).
Once it was done, everything was fine except the central display with the clock on it stopped working. I researched it at the time and it was apparantly a common fault that happens when after market head units are installed and so I did nothing about it.
Now the time has come to for me to sell my 206, and I'd like to re-fit the old original head unit back in.
Is this is a big job? Or is it just a case of re-attaching wires? Also, will the clock fix itself when the original unit is back in?
Any advise will be much appreciated,
Thanks for your time !!
Rob
1.4 Verve \r\n3 Door\r\n06 Plate\r\nPetrol
ramigojag
PostPosted: Tue Nov 01, 2011 3:20 am Up
i did this just at the weekend as long as you have the tool for taking the old headunit out its easy, took me all of 10 mins, my central display also didnt work with my aftermarket stereo
now with the original back in it shows me which which CD which track time its being played for etc.
Robj10
PostPosted: Tue Nov 01, 2011 3:27 am Up
Excellent. Thank you.
Where would I get my hands on one of these tools? And how much do they usually cost?
DanPug206
PostPosted: Tue Nov 01, 2011 3:29 am Up
Even if you don't have the tool, take the top centre console off, undo the 2 torx screws and gently pull the lower centre console, pull the connector blocks apart and take cd player out. Pretty straight forward
Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport
Robj10
PostPosted: Tue Nov 01, 2011 5:45 am Up
Are there any online tutorials or youtube videos which could guide me through the process? I've not done anything like this in a car before.
Cheers
sicskate
PostPosted: Tue Nov 01, 2011 7:57 am Up
Trade Rating: +13
Stop being a dumb a**e, I'm sure you can use your eyes, novice or not.
It's all plug and play, easy peasy!
307 1.4hdi Smile
Ali_H
PostPosted: Tue Nov 01, 2011 7:58 am Up
You might also need the code for the stereo once it's back in.
kurtis wrote:
PostPosted: Tue Nov 01, 2011 7:59 am Up
Shouldnt do on an 06 plate.
ramigojag
PostPosted: Tue Nov 01, 2011 8:13 am Up
Mines a 53 plate and i was expecting to need a radio code but thought id try it first because most radio code services are instant, but i didnt need the code just plugged straight in
the tools can be found in halfords there normally specific to the brand of the headunit it is
it is also possible to remove the HU without these tools using a small flat blade screwdriver but this is fiddly and risks scratching your centre console
Lecktorious
PostPosted: Tue Nov 01, 2011 8:18 am Up
Trade Rating: +59
Robj10 wrote:
DanPug206 wrote:
Even if you don't have the tool, take the top centre console off by pushing the cover towards the windscreen, undo the 2 torx screws and gently pull the lower centre console (it's held in by hidden clips), pull the connector blocks apart and take cd player out. Pretty straight forward
Cheers
As above - it's quite straightforward and a novice should manage without any issues.
'98 Nile Blue 306 GTi 6
copey
PostPosted: Tue Nov 01, 2011 8:37 am Up
yeh im sure on multiplexed the stereo is already coded to the car, how ever on none plexed ones you need the code
02 2.0 hdi d turbo
Ali_H
PostPosted: Tue Nov 01, 2011 10:27 am Up
Oops didn't read it was an 06 plate Laughing
kurtis wrote:
