Latest: eionpeu
Overall: 17120
Online Now [63]:
Visitors: 62
Today: 1791
Total: 97265978
Forums › The Car › 206 Problems › Eratic speedo
Eratic speedo
bigdave987
PostPosted: Sat Apr 13, 2013 3:21 pm Up
Hi all new her and also a virgin 206 owner this is my first one purchased it tonight its a 51 plate gti,all seems to work except the speedo which I noticed jumping from a steady speed to nothing then making its way back again,also as never had one of these do I need to look out for anything likely to bust on me straight away? This has problem been covered a million times and I appologise for that but the more info I can get on the car the better thanks all.
PostPosted: Sat Apr 13, 2013 7:18 pm Up
Is the abs light on?
bigdave987
PostPosted: Sun Apr 14, 2013 2:40 am Up
No,there ain't no lights on.
PostPosted: Sun Apr 14, 2013 8:27 am Up
Speed sensor on the gearbox or a busted cluster.
If changing the cluster, ensure you buy one with a lower mileage if you are plexed, or as close as you can if you're non-plexed.
Also worth trying a BSI reset (as it's free)
bigdave987
PostPosted: Sun Apr 14, 2013 8:59 am Up
Smile Sorry being new here have no idea what this plexed nob plexed is or this reset sorry bout this.
PostPosted: Sun Apr 14, 2013 9:09 am Up
It's the type of electrical system. If your radio stalk is long and thin, then it's non-plexed (old school normal electrics). If it's short and fat, then the you are multiplexed with CAN-VAN electrics.
The shut down procedure can be found in 206 Talk > Beginners Guide to a 206
bigdave987
PostPosted: Sun Apr 14, 2013 10:47 am Up
Okay so this reset could cure the problem if not new gear box sensor then I guess, how much are these sensors?
bigdave987
PostPosted: Wed Apr 17, 2013 12:40 pm Up
So just spook go a garage bout this and they tried convince me to pay £600for a new dash! I think not no matter what I said they weren't having it,is there anyone local to southend area from her that works on these cars?
