Latest: eltel666
Overall: 17146
Online Now [49]:
Visitors: 48
Today: 21071
Total: 116243755
Forums › The Car › 206 Problems › wont tick over
wont tick over
Go to page 1, 2, 3, 4, 5, 6, 7, 8  Next
dumdum0910
PostPosted: Wed Nov 09, 2011 1:32 pm Up
i have noticed every time i go to start my 206 it will stall striaght away , i have to put my foot on the throttle pedal to start , and also it stalls every time i change gear , what could be causing this problem . its had a ecu reset and no change. its a 1.1 2003
PostPosted: Wed Nov 09, 2011 1:33 pm Up
ICV
dumdum0910
PostPosted: Wed Nov 09, 2011 2:27 pm Up
i thort that may be the problem i did try and unplug it and plug it in while it was running and didnt make any diffrence , it will only tick over at 450rpm , ive adjusted the throttle for the time being until i get 5 mins to take it out and give it a clean
mattievrs
PostPosted: Wed Nov 09, 2011 2:51 pm Up
ICV or TPS
NO LONGER ACTIVE ON THE FORUM
dumdum0910
PostPosted: Wed Nov 09, 2011 3:20 pm Up
toke the icv out gave it a clean and replaced oring. still no change , i pushed the plunger all the way in thinking the engine will rev when first started but it didnt :S is there any way of testing the throttle position sensor? i no when i have my obd scanner plugged in it does read the position throttle ok.
mattievrs
PostPosted: Wed Nov 09, 2011 3:57 pm Up
Think the tps is part of the throttle housing. Whats the condition of the throttle housing ie clean/dirty? Have you cleaned the map sensor aswell?
dumdum0910
PostPosted: Wed Nov 09, 2011 3:58 pm Up
the throttle housing is in good condition , ive never cleaned the map sensor . how do you do that?
dumdum0910
PostPosted: Wed Nov 09, 2011 4:01 pm Up
when i toke the icv out there was some gunge around the plundger but not anything to worry about
mattievrs
PostPosted: Wed Nov 09, 2011 4:03 pm Up
guessing its an 8v? its on the left hand front of the inlet with wires going into it. It should have a couple of screws in it.
dumdum0910
PostPosted: Wed Nov 09, 2011 4:13 pm Up
yep i no were it is. i just toke it out it did have a bit of oil on it so blew what i could and cleaned as best as possible and still running low idle :S were the ecu has been reset so many times it wouldnt of lost its memory on were to tick over? just a possibilty
mattievrs
PostPosted: Wed Nov 09, 2011 4:17 pm Up
Clean everything with carb cleaner mate, not anything like wd40 as its oil based. Doesnt matter how many times you reset the ecu as its written on a chip to put it crudely.
Have you had the plugs out to see what condition theyre in?
dumdum0910
PostPosted: Wed Nov 09, 2011 4:21 pm Up
the plugs r only a month old as i fitted bosch super 4s but i will check tomorrow , i will clean the map , icv and tps and plugs and see what happens.
just want to add its only started playing up since i filled up with petrol from some were else as i normally go to shell but went to asda this time Shocked
mattievrs
PostPosted: Wed Nov 09, 2011 4:22 pm Up
if you can get a know good coilpack aswell, itll rule that out aswell.
dumdum0910
PostPosted: Wed Nov 09, 2011 4:24 pm Up
i want to try and resist buying a coil pack as i dont have that kinda money at the moment Sad
mattievrs
PostPosted: Wed Nov 09, 2011 4:27 pm Up
no one on here who has the same coilpack that would let you try it?
Page 1 of 8
