Latest: tc.206
Overall: 17147
Online Now [193]:
Visitors: 192
Today: 2795
Total: 116422970
Forums › The Car › 206 Problems › wont tick over
wont tick over
dumdum0910
PostPosted: Sun Nov 20, 2011 12:21 pm Up
think ive fixed it. will find out tomorrow when the engines cold. watched a vid on youtube and it said something about make sure the plunger is 1 1/8" out . so i went to my old mans place picked up the new icv made sure it was that far out and it ran smooth Smile fingers crossed
dumdum0910
PostPosted: Mon Nov 21, 2011 9:37 am Up
So all was fine this morning . Car started fine ran smooth drove to heathrow . Sat for 2 hours started fine again . Drove home went to start it again after 10minutes and the revs shot straight up to 3000rpm then down to 2000rpm and started bouncing Sad will have a look later.
dumdum0910
PostPosted: Mon Nov 21, 2011 12:08 pm Up
sorry about rubbish pic , you can see in the pic the bit of plastic is missing , ive left it to glue and will see what happens tomorrow
PostPosted: Mon Nov 21, 2011 3:09 pm Up
Make sure you have a good tight seal around the ICV.
Should come with a new seal ring.
And clean all the crap off there while you're at it.
dumdum0910
PostPosted: Mon Nov 21, 2011 3:13 pm Up
it did come with a new seal i just put a bit of multi purpose grease around it to make sure it was sealed Smile . typical i get it running perfect then the throttle body decides it wants to fall apart
PostPosted: Mon Nov 21, 2011 3:25 pm Up
Oops..
The only grease you should be using on rubber seals is either silicon grease, or dry-type PTFE. Otherwise you're compromising it's sealing ability and it will dissolve the rubber over time.
I would thoroughly clean it all off and wash the sealing ring with dish-soap and warm water.
Looks like you're getting there though.. Smile
dumdum0910
PostPosted: Mon Nov 21, 2011 3:28 pm Up
im gunna clean it all off and start again tomorrow. i might put a bead or silcone sealer around it . i no this works as ive used it before on other cars .
PostPosted: Mon Nov 21, 2011 3:35 pm Up
OK. But let it set first.
There is one hell of a vacum there as I found out when I nearly got my hand sucked-in a throttle body, and it was only a 1.4 Shocked
Good luck.
dumdum0910
PostPosted: Mon Nov 21, 2011 3:42 pm Up
i will dont worry , im going to a car show on saturday so will take my time with it
dumdum0910
PostPosted: Mon Nov 21, 2011 3:46 pm Up
dumdum0910 wrote:
just want to add its only started playing up since i filled up with petrol from some were else as i normally go to shell but went to asda this time Shocked
Its taken 7 pages to get to this vital bit of new info. Rolling Eyes
dumdum0910
PostPosted: Mon Nov 21, 2011 3:47 pm Up
gives people something to read Razz
PostPosted: Mon Nov 21, 2011 3:49 pm Up
Oh..
Where was this post?
PostPosted: Mon Nov 21, 2011 3:55 pm Up
V9977 wrote:
Oh..
Someones been editing on here Confused
PostPosted: Mon Nov 21, 2011 4:00 pm Up
MrBSI wrote:
V9977 wrote:
Oh..
Maybe they feel it's not as relevant as initialy thought.
But it might be.
Page 7 of 8
