Forums › The Car › 206 Talk › 180 gti exhaust clamps |
Posted: Wed Nov 09, 2011 2:32 pm |
Anone know the size and or part number for the exhaust clamps for the exhaust middle section where it connects to the back box and the cat?
Posted: Wed Nov 09, 2011 5:21 pm |
Last time I looked up the exhaust clamp & rubbers for a 206 they where shockingly cheap & came as a fitting kit for around £8
Look them up on Peugeot Service Box.
Posted: Wed Nov 09, 2011 6:06 pm |
Cheers mate.
Posted: Thu Nov 10, 2011 6:01 pm |
part # 1713 69...... fixing clamp .....diameter 74.5mm £4.78 each inc vat.
Posted: Fri Nov 11, 2011 7:16 am |
Proper Peugeot clamps are much better than aftermarket clamps.
