Posted: Tue Nov 08, 2011 11:52 am |
Is a 3521K2 the right wishbone for a 206CC (basically same as GTI I think!)
My copy of the parts manual is a bit "dodgy" ...
Posted: Tue Nov 08, 2011 11:56 am |
All 206 wishbones will fit, the GTi ones just have metal bushes.
Posted: Tue Nov 08, 2011 11:59 am |
I guessed they would all fit, but wanted to check what the correct part is ... any idea?
Posted: Tue Nov 08, 2011 12:01 pm |
Well, I'm not sure of this... Service box reports a lot of different parts numbers for wishbones... 3521K2 seems not to fit on CC...
| Silver grey RC|Pug Sport remap|Group A induction|Supersprint backbox|lower strut bar|RCCup wishbones|Eibach Pro-Street-S|302mm brakes+23.8 master cylinder|Vibra Technics|Quaife LSD|Cupra R splitter|modded bonnet vent|black Valeos|207i tail lights|Chromed rear foglight|Bi-xenon 6000k+all led (in+out)|406 rear mirror | |
Posted: Tue Nov 08, 2011 12:02 pm |
That's the right one on a 1.6 16v and is the old part number, new one is 3521 R7
Posted: Tue Nov 08, 2011 12:13 pm |
So dork selling it as a GTI arm is wrong then!
Posted: Tue Nov 08, 2011 12:53 pm |
gazza82 wrote: |
So dork selling it as a GTI arm is wrong then! |
1.6 16v and gti and RC and cc and 2.0HDi and 1.6HDi use the same wishbone.
Posted: Fri Nov 11, 2011 5:56 pm |
Not a dork then!
Posted: Sat Nov 12, 2011 2:53 am |
Quite simply there is a wishbone for sports range cars and another for other models.
