Posted: Sun Nov 20, 2011 9:11 am |
I frequently drive through a village where 16 year old kids think its really funny to walk in the road when you are approaching 10 metres away from them, then laugh when you have slammed your brakes on to avoid hitting them, its very dangerous. So I'm thinking of something to teach the little sh*ts a lesson.
Has anyone ever fitted one of these?
www.larkspeed.com/inde...451128&a=i
Or even if you have changed the horn, I'd like to know how its done
edit: even better, the nautilus version www.youtube.com/watch?...re=related
Posted: Sun Nov 20, 2011 9:41 am |
You run them over, problem sorted mate. They won't do it again haha
| Saphire Blue 206 (Gti Replica) SOLD
08 Seat Ibiza Sport | |
Posted: Sun Nov 20, 2011 9:46 am |
I've bolted a klaxon horn to the inside of my grille using the radiator housing. Then fitted a push switch next to the airbag key slot, that would make em move!
Edit: also I used the ignition live from my radio to power it so it can't drain my battery if it malfunctions
| You never really learn to swear until you learn to drive | |
Posted: Sun Nov 20, 2011 10:04 am |
Got 405 twin tone horns on mine, plenty loud enough
Just dont stop, they will soon move
Posted: Sun Nov 20, 2011 10:12 am |
Is it easy to fit? I'm looking for something that is plug and play
Where did you get them from?
Posted: Sun Nov 20, 2011 10:14 am |
Andrewxps wrote: |
Where did you get them from? |
Out of my stock collection of Peugeot part's.
Isnt plug & play, had to get the soldering iron out.
GTI 180 has twin tone horns, no idea if there as loud or plug & play
Posted: Sun Nov 20, 2011 10:20 am |
Posted: Sun Nov 20, 2011 10:46 am |
Should the battery be disconnected when changing the horn?
MrBSI - stock collection of Peugeot parts.. extensive knowledge about Peugeots.. I get a feeling you work at Peugeot!
Posted: Sun Nov 20, 2011 10:58 am |
Andrewxps wrote: |
MrBSI - stock collection of Peugeot parts.. extensive knowledge about Peugeots.. I get a feeling you work at Peugeot! |
Wrong
Posted: Sun Nov 20, 2011 11:13 am |
A pair of air-horns will make them jump ...
Had to cut the wires to the original horn, but left that in place. So if we do take the air's out, can splice the connector back in. Comes with a compressor unit that I fitted to the radiator surround with plastic number plate screws and nuts. Used the existing wiring
as it was fed by a relay didn't need the one that came with the kit.
Fitted these to the HDi when my daughter had it .. Junction 4 of M40 is Handy Cross. Worse laid out roundabout anywhere I know and we're constantly getting cut-up by Chelsea tractors ...
The air horns say "get out the way!"
Posted: Sun Nov 20, 2011 12:45 pm |
Fitted a stebel nautilus to my motorbike, loud but nothing like as loud as a twin air horn. Two tone horn from a higher spec car should do the trick, just bite your lip and slow down for the kids - you know you'll be in deep s**t if you hit one of em.
