Posted: Tue Nov 15, 2011 8:28 pm |
ive been told that peugeot introduced a self cleaning fuel filter inside the tank. post 2002.
i have a 2004.
now, 3 or 4 times when im down to the last markers on the fuel guage and fuel light coming on, the car has been really lumpy.
doesnt idle properly and sometimes it jolts, EML comes on and a brief loss of power but its for about 2 seconds then normal service resumes.
im going to try a bottle of petrol tank cleaner or something because if my model doesnt have a filter outside of the tank then its all i can do!
going to clean the throttle body tomorrow aswell. any guides or advice
thanks!
| | ![](images/spacer.gif) |
Posted: Wed Nov 16, 2011 4:08 am |
there's a guide in the how to for cleaning throttle bodies, but to be honest its dead straight forward, just disconnect battery live before you start taking plugs for ICV and intake temp sensor out.
Posted: Wed Nov 16, 2011 7:01 am |
1) Intake temp sensor is part of the MAP sensor if it has 4 pins.
2) No-need to disconect battery when unpluging sensors as long as the engine is not running.
Unless you want the ECU to re-learn parameters.
3) In-tank filter has nothing to do with date of manufacture. Mine is 2001 and has no external filter.
4) I would check possibility of contaminant in the tank and/or condition of fuel pump.
Posted: Wed Nov 16, 2011 10:17 am |
leave the battery plugged in and surely you'll have flags in your diag's next time?
each to his own I guess?
Posted: Wed Nov 16, 2011 12:02 pm |
panzer360gti wrote: |
each to his own I guess? |
How when then cars not running or no keys in ignition???
Posted: Wed Nov 16, 2011 1:13 pm |
No, you don't if the engine is not running as the ECU does not care.
Have done this with every sensor in there and never had EML come on
or codes appear.
CAN/VAN bus is a different matter though.
Posted: Wed Nov 16, 2011 1:45 pm |
If the engine/ignition aint on, how is it going to know the sensor is disconnected?
| Renault Clio III RS - Race Car ![Cool Cool](images/smiles/icon_cool.gif)
Former Poverty 206 XS 1.6Turbo Owner ![Razz Razz](images/smiles/icon_razz.gif) | |
Posted: Wed Nov 16, 2011 2:46 pm |
Maybe if he doesnt disconnect battery , then he will get big electric shock and his hair will go all fuzzy?
I was bollocked by a mechanic (in a polite having a laff way) for not taking live off, hes a mechanic of 25 years, maybe I misheard him and he said pull live off for some other reason.
Either way, Im sure taking the live off has its benefits, just as leaving it on does.
Peace out brothers.
