Latest: elelectricistadeMateo
Overall: 17127
Online Now [47]:
Visitors: 45
Members: 1
Today: 20918
Total: 100393601
Forums › The Car › 206 Talk › where does this go..?
PostPosted: Mon Nov 21, 2011 9:32 am Up
just put climate control stuff in car but cant for life of me see where this goes..........
also where does the temp sensor go also, same case as above, spent ages looking were it goes Laughing
Embarassed
thanks Very Happy
Alex206
PostPosted: Tue Nov 22, 2011 8:58 am Up
as i can remember, that's a tem sensor for cabin and it goes behind the glove box, but i'm not so sure...
PostPosted: Tue Nov 22, 2011 9:52 am Up
Right hand side of the glove box, behind the little vent next to where it says 'airbag'
PostPosted: Wed Nov 23, 2011 2:18 pm Up
Lee is a Pug master to listen to what he says :D,was it a hard job to retro fit climate control instead of manual one?
PostPosted: Wed Nov 23, 2011 2:48 pm Up
Behind the airbag passenger side, i did this conversion years ago
Bit slow ben Wink
Want to swap it for a dual zone climate unit out of a newer peugeot sometime though
PostPosted: Wed Nov 23, 2011 3:40 pm Up
easy
Bit slow ben Wink
yer bit slow but i got round to having a go at it too in the end lol Razz
PostPosted: Thu Nov 24, 2011 6:08 am Up
Yes it's the cabin sensor. Quite difficult to slide back in place due to access, might be easier to remove the stereo or even glovebox to help.
PostPosted: Fri Nov 25, 2011 12:30 pm Up
nice one, there is no stereo or glovebox in car atm, Very Happy dash got to come out again soon too so should be easy then Very Happy lol
PostPosted: Wed Dec 07, 2011 12:54 pm Up
wish that you did a "How to" for this project,it will be very helpful and valueable Smile
PostPosted: Wed Dec 07, 2011 1:01 pm Up
I have another heater matrix, motor, blower and wiring loom if anyone want one.
Only thing I don't have is the screen
PostPosted: Fri Dec 09, 2011 6:52 am Up
cant for the life of me see where this goes in car Sad does it need to have an airbag fitted?? i have not airbag just a cover.
PostPosted: Fri Dec 09, 2011 7:06 am Up
See the little vent straight next to where it says AIRBAG - www.ebay.co.uk/itm/PEU...500wt_1127
It goes there.
It's only a temp sensor, so you can fix it anywhere tbh as long as it's inside the cabin
PostPosted: Fri Dec 09, 2011 1:54 pm Up
Prelex or MUX one Lee Smile
PostPosted: Fri Dec 09, 2011 3:48 pm Up
Non-plexed
