Latest: sparrowdclxvi
Overall: 17139
Online Now [116]:
Visitors: 115
Today: 22190
Total: 112677090
Forums › The Car › 206 Problems › Low compression
Low compression
DavidPCoates
PostPosted: Sat Dec 03, 2011 11:17 am Up
I think I already know the answer to this but have done a compression test with the folllowing results.
11.5, 9.5,9.5,11 KG/cm.
Head gasket gone between cylinder 2 & 3?
Dave
Dave Coates
PostPosted: Sat Dec 03, 2011 11:59 am Up
you will need to put oil into the cylinder to check if the ring is worn or not.
