Posted: Tue Nov 22, 2011 3:43 pm |
Hi
I have a 52 plated 206Gti
I am chasing a miss fire on it and think I have been sold another duff coil pack as the miss fire has not gone away.
I start it
Drive it, it goes like a train for 5 miles
then the engine light comes on and it miss fires, like its on 3 cyl
then sometimes if I turn it off and wait 5 minutes and turn it on, its gone for good
I can turn it back on and it will not go away
then as I drive along it goes away, it goes like a train again and all is great, but the light is on
Tried coil pack, spark plugs, cleaned injectors, new seals on injectors, contact cleaner on all electrical plugs and sockets.
Rolling Eyes
Posted: Tue Nov 22, 2011 3:52 pm |
Have you actually had it code read?
Posted: Tue Nov 22, 2011 4:09 pm |
No, is it a dealer only thing or a good garage can help?
Posted: Tue Nov 22, 2011 4:27 pm |
Well you've done it the idiot and expensive route then.
Any decent garage should be able to do it.
Posted: Tue Nov 22, 2011 4:29 pm |
Lee wrote: |
Any decent garage should be able to do it. |
even AA man can read the code
Posted: Tue Nov 22, 2011 4:49 pm |
ive you was a bit closer i could of read the codes for you
| if it dont scuff the ruff it aint low enuf | |
Posted: Wed Nov 23, 2011 2:08 am |
Could be dodgy hydraulic lifters. Expensive for genuine Peugeot parts and a bit of a job to change them. An oil change could help but unlikely.
Posted: Wed Nov 23, 2011 6:52 am |
Wonder if its got NGK spark plugs fitted?
Posted: Thu Nov 24, 2011 3:38 pm |
I have changed to NGK recently.
Whats the issue with NGK?
Posted: Thu Nov 24, 2011 3:47 pm |
PSA coil packs dont like them lol it sends them funny...
Posted: Thu Nov 24, 2011 5:14 pm |
CrazyDavid wrote: |
Whats the issue with NGK? |
Fit a set of Bosch spark plugs & the misfire should cure itself
