Posted: Fri Nov 25, 2011 4:39 am |
I had to remove my driveshaft when I done my wishbone lost about a litre of gear box oil is it ok to just top it up or have do drain rest and start a fresh?
Posted: Fri Nov 25, 2011 5:14 am |
Might as well drain it and put new in
Posted: Fri Nov 25, 2011 5:51 am |
Peugeot / Citroen main dealer for gearbox oil, its cheap enough & will be the correct stuff
Use the filler / level plug on the side of the gearbox behind passenger side plastic arch liner.
Posted: Fri Nov 25, 2011 6:46 am |
Yeah ok cheers for the advice is the drain plug on bottom of the gear box I take it?
Posted: Fri Nov 25, 2011 7:01 am |
Yeah
Posted: Thu Dec 01, 2011 11:05 am |
How much does it roughly hold?
| GTI 138 facelift - Runabout
335d M Sport - Cruiser | |
