Latest: Kifi69
Overall: 17183
Online Now [479]:
Visitors: 478
Today: 40361
Total: 144668404
Forums › The Car › 206 Talk › bleed time
bleed time
Forum Index › 206 Talk
greenpug2222
PostPosted: Fri Jan 13, 2012 3:28 pm Up
hi,
can some one tell me the best way to fill and bleed the coolant in my 1.4lx.
The only bleed nipple i can see is on the heater blower hose. Are there anymore i need to know about?
Cheers
Joe
why wont you work??????????????????? ARGH F**k it!!!!!
PostPosted: Fri Jan 13, 2012 4:37 pm Up
there is 3...
one next to the thermostat and one near to the bulk head and one is top of the radiator
millerman
PostPosted: Tue Jan 17, 2012 1:19 pm Up
Seabook, just to confirm as i will need to bleed our 1.4 when i change the stat, the one atop the rad is a round metal one with a hex cutout yes? The one next to the stat looks like it needs an allen key and may be made of metal yes? The one on the heater hose near bulk head is a plastic screw out jobbie, do these tend to snap off? In what order are thay bled? Confused
If you think no one cares, try missing a mortgage payment!
PostPosted: Tue Jan 17, 2012 4:22 pm Up
I never bothered when I done mine last month.
Changed stat, top up cooling system, run engine till cooling fan cuts in then out again, switch it off, let engine fully cool & then top it up to the correct level.
Never had to use the bleed screws yet on a 206 & ive never had a problem with air being trapped in the system.
PostPosted: Tue Jan 17, 2012 5:25 pm Up
yes you are right
no idea about the order, i start from the radiator, themostat and then bulk head.
it took me less than 30 sec to bleed them all so why not? never snap on mine as they should be tighten by hand
millerman
PostPosted: Wed Jan 18, 2012 1:00 am Up
Cheers guys, Mr BSI, i only mention bleeding because the heater in my wifes 1.4 lx is only luke warm, so, i'm gonna change the stat and bleed the system, poor Woman has been frozen these last couple days. Wink
PostPosted: Wed Jan 18, 2012 10:04 am Up
They normally bleed themselves, very rare you need to use the bleed screws.
