Online Now [1047]:
Visitors: 1046
Today: 50727
Total: 151839442
Forums › The Car › 206 Problems › sudden power steering failure
colinn
PostPosted: Tue Nov 29, 2011 2:42 pm Up
as above - failed suddenly and completely on a roundabout on way home from work and scared the s**t out of me - thought I had lost all steering for a sec
and the battery warning light has come on
last week I posted about a screeching noise on turning at low speed but the nojse disappeared by itself so l didn't investigate further
must check steering fluid in a mo but sudden failure and battery warning seems odd
ideas anyone?
PostPosted: Tue Nov 29, 2011 2:44 pm Up
Your Aux belt has come off
burnmw
PostPosted: Tue Nov 29, 2011 2:51 pm Up
Yup, this is your problem.
You can continue to drive the car but your battery will no longer be charging, so probably not a good idea. Oh and you will obviously have no power steering (but you've already found that bit out).
Wants a new aux belt, and check you've not damaged anything else in the process. Have heard of aux belts coming off at speed and going through the cam-belt cover.
The day that Microsoft makes something that doesn\'t suck is the day that they start making vacuums.
colinn
PostPosted: Tue Nov 29, 2011 3:00 pm Up
thanks guys for such quick and definite diagnosis - yes charging circuit is definitely a more immediate problem - will try and get it sorted in the morning
PostPosted: Tue Nov 29, 2011 3:02 pm Up
Might be a idea to get the timing checked if the bottom pulley looks damaged.
I did 50 miles with no aux belt
Also your AC won't work either if you have it
Wants new tensioners/rollers and a belt
colinn
PostPosted: Tue Nov 29, 2011 3:12 pm Up
yeah just checked Haynes to see exactly what the belt does - I can mess about with in-car electrics but really don,t know enough about engines - hopefully can get it into a garage next door to work in the morning
burnmw
PostPosted: Wed Nov 30, 2011 3:10 am Up
What.. some of these cars still have working AC?? Surprised
Good luck getting that started Thumb Up
PostPosted: Wed Nov 30, 2011 4:32 am Up
Impossible if you have no aux belt
