Online Now [572]:
Visitors: 572
Today: 134551
Total: 152772022
Forums › The Car › 206 Problems › oil light and warning light flashing but oil is full
Go to page Previous  1, 2
PostPosted: Sat Dec 03, 2011 10:30 am Up
gavlar83 wrote:
Lee wrote:
On a modern engine the oil light is generally too late, damage has been done Wink
Oil is the blood of your car. If you cut a vein in your arm, you aren't going to be 100% are you?
i get what your saying,can it still be damaged when the oil is full?also if it is damaged what kind of damage am i looking at?
Oil level isnt gonna matter if there's sod all oil pressure to pump the oil round the engine.
Damage = replacement lump time.
PostPosted: Sat Dec 03, 2011 10:31 am Up
Too much oil is as bad, if not worse than too little
gavlar83
PostPosted: Sat Dec 03, 2011 10:47 am Up
ok thanks alot guys for the info much appreciated
is learning slowly but surely Smile
Signature Removed - Please See Your PM's
gavlar83
PostPosted: Sat Dec 03, 2011 10:52 am Up
just a quick question off topic,what do you guys think of MG ZR,s? been offerd 1 but not sure about them,do u guys no anything about them?thanks
PostPosted: Sat Dec 03, 2011 10:56 am Up
Rusty old Rover s**te Wink
Body & trim parts are difficult to get hold of even 2nd hand, they didnt come of to well in Euroncap carsh tests either Laughing
A manufacturer is really scraping the barrel when they do an Atomic Kitten special edition Rolling On The Floor Laughing
Look for an MG Atomix if you really must as these have extra kit over standard but there all pretty poorly speced anyway.
gavlar83
PostPosted: Sat Dec 03, 2011 10:59 am Up
nice 1 i thought as much Very Happy
PostPosted: Sun Dec 04, 2011 1:28 am Up
gavlar83 wrote:
i thought the oil light was to say if u needed oil or not,not oil pressure?
It's pressure.
PostPosted: Sun Dec 04, 2011 6:35 am Up
my frd's 306HDi engine went busted because his parent keep toping up half a litre of oil every month Laughing
although the engine was fixed under dealer waranty Laughing
gazza82
PostPosted: Sun Dec 04, 2011 10:04 am Up
Best case is the oil pressure switch has failed. Worse case is you've now got damaged crank shaft bearing shells, and if you keep using it, a damaged crank.
PostPosted: Sun Dec 04, 2011 11:04 am Up
Or even think of it as a heart pumping the blood around. No heart pumping, no blood circulating.
Page 2 of 2
