Posted: Mon Dec 05, 2011 6:56 am |
put a battery in yourself, its a piece of pee
Posted: Mon Dec 05, 2011 6:58 am |
If you cant change a simple car battery you cant be classed as a MAN
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
Posted: Mon Dec 05, 2011 7:00 am |
Mattie-RS wrote: |
If you cant change a simple car battery you cant be classed as a MAN  |
lol. i've never tried! dont worry i will change it!
Posted: Mon Dec 05, 2011 7:25 am |
rich_xs wrote: |
Mattie-RS wrote: |
lol. i've never tried! dont worry i will change it! |
BSI needs to be shut down correctly before you disconnect the battery & then booted back up correctly afterward battery replacement.
Posted: Mon Dec 05, 2011 7:27 am |
MrBSI wrote: |
rich_xs wrote: |
Mattie-RS wrote: |
BSI needs to be shut down correctly before you disconnect the battery & then booted back up correctly afterward battery replacement. |
whoa....ok now im stuck! lol.
Posted: Mon Dec 05, 2011 7:29 am |
rich_xs wrote: |
MrBSI wrote: |
rich_xs wrote: |
Mattie-RS wrote: |
whoa....ok now im stuck! lol. |
www.206info.co.uk/Foru.../t=95.html
Posted: Mon Dec 05, 2011 7:38 am |
MrBSI wrote: |
rich_xs wrote: |
MrBSI wrote: |
rich_xs wrote: |
Mattie-RS wrote: |
www.206info.co.uk/Foru.../t=95.html |
cool. whats DIAG equipment? seems like i trust the garage more than me to do it!
Posted: Mon Dec 05, 2011 7:42 am |
rich_xs wrote: |
MrBSI wrote: |
rich_xs wrote: |
MrBSI wrote: |
rich_xs wrote: |
Mattie-RS wrote: |
cool. whats DIAG equipment? seems like i trust the garage more than me to do it! |
You wont have any diag equipment connected so dont worry about it.
It means a scanner etc connected to the diag port.
Posted: Mon Dec 05, 2011 8:13 am |
its easy, just follow those steps and you really cant go wrong
Posted: Tue Dec 06, 2011 5:16 am |
Thanks for the replies, I'm getting a Silver Varta at lunchtime and will fit it later - hope a new battery helps you Rich XS!
Doing voltage tests last night, I noticed the battery is original, almost 9 years isn't too bad for a OE battery.
Posted: Tue Dec 06, 2011 6:03 am |
davek wrote: |
Doing voltage tests last night, I noticed the battery is original, almost 9 years isn't too bad for a OE battery. |
picking my bosch S5 one up tomorrow. will you let me know if you air bag light goes off?
Posted: Tue Dec 06, 2011 7:05 am |
davek wrote: |
Good old Varta
Posted: Tue Dec 06, 2011 4:43 pm |
Hya
I'm having the same starting problems now it's turned colder. Normally the car starts first time but now it takes three goes. I then get the air bag light, auto locking etc.
Funny enough the battery voltage is showing 12.5 when the car has been run and so warm.
Did anyone else check their battery's voltage
Cheers
Pete
Posted: Tue Dec 06, 2011 5:28 pm |
petejax wrote: |
Hya
Cheers
Pete |
Try checking the battery voltage BEFORE you attempt to start the car, you should find it low.
12.5 volts after its been run is low anyway.
Posted: Wed Dec 07, 2011 4:30 pm |
Thanks, will try that.
Any idea what the voltage should be?
Cheers
Pete
