Latest: Worthy967
Overall: 17143
Online Now [82]:
Visitors: 80
Members: 1
Today: 2419
Total: 114880470
Forums › The Car › 206 Problems › HDI starting problems
copey
PostPosted: Mon Dec 05, 2011 6:56 am Up
put a battery in yourself, its a piece of pee
02 2.0 hdi d turbo
Mattie-RS
PostPosted: Mon Dec 05, 2011 6:58 am Up
If you cant change a simple car battery you cant be classed as a MAN Wink
r1ch
PostPosted: Mon Dec 05, 2011 7:00 am Up
lol. i've never tried! dont worry i will change it!
PostPosted: Mon Dec 05, 2011 7:25 am Up
BSI needs to be shut down correctly before you disconnect the battery & then booted back up correctly afterward battery replacement.
r1ch
PostPosted: Mon Dec 05, 2011 7:27 am Up
whoa....ok now im stuck! lol.
PostPosted: Mon Dec 05, 2011 7:29 am Up
www.206info.co.uk/Foru.../t=95.html
r1ch
PostPosted: Mon Dec 05, 2011 7:38 am Up
cool. whats DIAG equipment? seems like i trust the garage more than me to do it!
PostPosted: Mon Dec 05, 2011 7:42 am Up
You wont have any diag equipment connected so dont worry about it.
It means a scanner etc connected to the diag port.
copey
PostPosted: Mon Dec 05, 2011 8:13 am Up
its easy, just follow those steps and you really cant go wrong
02 2.0 hdi d turbo
davek
PostPosted: Tue Dec 06, 2011 5:16 am Up
Thanks for the replies, I'm getting a Silver Varta at lunchtime and will fit it later - hope a new battery helps you Rich XS!
Doing voltage tests last night, I noticed the battery is original, almost 9 years isn't too bad for a OE battery.
r1ch
PostPosted: Tue Dec 06, 2011 6:03 am Up
picking my bosch S5 one up tomorrow. will you let me know if you air bag light goes off? Very Happy
PostPosted: Tue Dec 06, 2011 7:05 am Up
Good old Varta Cool
petejax
PostPosted: Tue Dec 06, 2011 4:43 pm Up
Hya
I'm having the same starting problems now it's turned colder. Normally the car starts first time but now it takes three goes. I then get the air bag light, auto locking etc.
Funny enough the battery voltage is showing 12.5 when the car has been run and so warm.
Did anyone else check their battery's voltage
Cheers
Pete
petejax
PostPosted: Tue Dec 06, 2011 5:28 pm Up
petejax wrote:
Hya
Cheers
Pete
Try checking the battery voltage BEFORE you attempt to start the car, you should find it low.
12.5 volts after its been run is low anyway.
petejax
PostPosted: Wed Dec 07, 2011 4:30 pm Up
Thanks, will try that.
Any idea what the voltage should be?
Cheers
Pete
petejax
Page 2 of 3
