Latest: sparrowdclxvi
Overall: 17139
Online Now [130]:
Visitors: 129
Today: 34608
Total: 113105959
Forums › The Car › 206 Talk › Mat Material
Mat Material
maverick1984
PostPosted: Tue Dec 06, 2011 6:01 am Up
Hi,
I have a 206 van and I need to replace the rear carpet. The original one supplied by Peugeot is thin and ok but I have spilt something on it form going to the tip and I cant get rid of the smell!!
I would like to replace this with something of the same material that normal car mats are made from. Does anyone know where I can get this material from? I'd imagine a 2m x 2m piece will be ok and I could use the old piece as a template to cut from or an alternative is the rubber mat material and again I would cut it myself to fit. I have searched the web for 206 van load liners but they dont seem to make them.
2005 1.4hdi Van
PostPosted: Tue Dec 06, 2011 7:25 am Up
How about using a bit of rubber flooring?
Plenty of places supply it on a roll, maybe a cheap offcut will do the job?
austin316
PostPosted: Tue Dec 06, 2011 8:22 am Up
I went to peugeot to look at getting this done for my peugeot, and they quoted me about £600, so i tried looking around, but also couldnt find anything
5 door
1.1 8v
04 reg
PostPosted: Tue Dec 06, 2011 9:05 am Up
The carpet I used to have in the back of the van had like a rough plastic/rubber on the back of it similar to the grippy stuff on the back of mats. Not sure what it's called though.
You could check with Northantsben and see if he can help you out with anything.
Edit. This is the place I used to get mats from, so you might be able to get an idea from them
