Online Now [468]:
Visitors: 467
Today: 149095
Total: 152784206
Forums › The Car › 206 Talk › 206 GTI 180 Timing Belt Change
Forum Index › 206 Talk
Go to page Previous  1, 2
wasssssup
PostPosted: Wed Dec 07, 2011 1:04 pm Up
Is it really necessary to do that last bit on the printout about turning the crank pully after putting the belt on?
on a quest for 200bhp Very Happy
Big_Rich180
PostPosted: Wed Dec 07, 2011 1:06 pm Up
Presumably its to make sure the belts on correctly?
ramigojag
PostPosted: Wed Dec 07, 2011 1:07 pm Up
I think because if its been timed wrong turning the crank by hand will not damage anything whereas if you start it and its timed wrong....
Woops
wasssssup
PostPosted: Wed Dec 07, 2011 4:46 pm Up
no i mean the repositioning of flange bit at the end is that really necessary as it looks like you need a lot of special tools to do it lol
PostPosted: Thu Dec 08, 2011 5:57 am Up
Pay someone else to do it then.
gazza82
PostPosted: Thu Dec 08, 2011 6:16 am Up
I think you only need to do that if the holes don't line up again after fitting the new belt and turning it over by hand! I know when I did the CCs (138bhp), everything was fine and holes lined up fine. I even had a local Pug/Citroen specialist have a look as he was around sorting my air con.
Took me about 6 hours, but I took my time as I wanted it to be right! Getting the covers on/off requires some dexterity! Wink
ramigojag
PostPosted: Thu Dec 08, 2011 12:53 pm Up
Too true i think thats probably the hardest part about the change
SAB206
PostPosted: Thu Dec 08, 2011 1:07 pm Up
It's not the best job in the world to do, usually takes more than 4hours unless there is prior experience.
the first time i had mine done, they locked the exhaust cam in the wrong pin, making it be 1 tooth out, but it made a big difference on noise/performance, so make sure everything is locked up solidly and double check everything...you don't want to be doing it twice.
www.sab-graphics.com
I AM SYDLEXIC!
Page 2 of 2
