Online Now [367]:
Visitors: 367
Today: 49660
Total: 142560106
Forums › The Car › 206 Talk › possible steering wheel upgrade>>>>
craigdmjv
PostPosted: Thu Dec 08, 2011 2:07 am Up
i think the ds3 steering wheel looks to have the same connections as a 206 so i wonder if one would actually fit here it is and here is the pug one
HDI90
PostPosted: Thu Dec 08, 2011 3:37 am Up
The splines on the collum might line up but the air bag will be different , and you wont want one with a citroen badge will you
GTI 180
copey
PostPosted: Thu Dec 08, 2011 3:47 am Up
and im quite certain when new mot rules come in, if your car has an airbag, and your remove it, its a fail
02 2.0 hdi d turbo
PostPosted: Thu Dec 08, 2011 5:27 am Up
Will also be a fail if the airbag warning light is on / not working or doesnt go through the correct check sequence at start up Wink
PostPosted: Thu Dec 08, 2011 5:30 am Up
Plus the Citroen DS3 airbag is only single stage & the multplexed 206 needs a dual stage airbag so even electrically the Citroen airbag is no good Laughing
copey
PostPosted: Thu Dec 08, 2011 5:43 am Up
personally its beyond me why anybody would want to loose a key safety feature anyways
02 2.0 hdi d turbo
PostPosted: Thu Dec 08, 2011 5:52 am Up
Plenty of idiots on here seem to want to Wink
Icetto
PostPosted: Thu Dec 08, 2011 8:18 am Up
I also thought about getting the DS3 steering wheel.
You won't use the citroen cover and airbag. You will use your existing cover and airbag. My local Peugeot dealership told me it can be transfered like that
PostPosted: Thu Dec 08, 2011 8:22 am Up
how can the 206 airbag fit? it looks a different shape
PostPosted: Thu Dec 08, 2011 8:59 am Up
Can't you remove the airbag from the cover and fit it inside the DS3 cover?
Nat-T
PostPosted: Thu Dec 08, 2011 9:18 am Up
What He Said
Euro/Smoothed 2003 China Blue Verve
Rayvern Hydraulics
Schmidt 3-piece splits/Mercedes Wheels + custom adapters to 5x112
Lots of smoothed custom bodywork Wink
PostPosted: Thu Dec 08, 2011 10:26 am Up
would that be advisable? depending on the strength of the covers, the airbags could be of different design type? So it could effect what happens if you crash and need the airbag?
Icetto
PostPosted: Thu Dec 08, 2011 12:38 pm Up
Nat-T wrote:
What He Said
That's what I asked 2 Peugeot dealerships in Cape Town and both said it can be done.
