Latest: Andyblue64
Overall: 17123
Online Now [205]:
Visitors: 204
Today: 10974
Total: 98014997
Forums › The Car › 206 Talk › Is this correct for a diesel?
r1ch
PostPosted: Sun Dec 11, 2011 5:25 am Up
Hey, my mate was in the 206 with me the other day and he saw me start it up and said i was doing it wrong because its a diesel....what i should do he said was turn the key twice so the electrics come up and then wait 5 seconds. Then turn it for the 3rd time to turn the engine over. Is that the correct way? I've always just put the key in and turned it fully to fire up the engine. Or does it not matter??
Its the first diesel car i've owned.
copey
PostPosted: Sun Dec 11, 2011 5:28 am Up
depends if the glow plugs need heating up or not
02 2.0 hdi d turbo
PostPosted: Sun Dec 11, 2011 5:34 am Up
Most modern diesel you dont need to wait as the glow plugs will be hot enough to start.
I always wait until the fuel pump has stopped before starting up.
r1ch
PostPosted: Sun Dec 11, 2011 5:36 am Up
so is that after about 5 seconds? is a 2005 206 classes as modern a diesel?
PostPosted: Sun Dec 11, 2011 5:37 am Up
Yes and yes
Always best to wait at this time of year aswell
r1ch
PostPosted: Sun Dec 11, 2011 5:41 am Up
Yes and yes
cool, cheers. by the way, i can see the flip key in your signature. did you get that off a group buy on here?
PostPosted: Sun Dec 11, 2011 5:45 am Up
Yes I was the one who did the group buy mate
r1ch
PostPosted: Sun Dec 11, 2011 5:46 am Up
is there going to be another soon do you know?
PostPosted: Sun Dec 11, 2011 5:48 am Up
Possible I will have to look into it
r1ch
PostPosted: Sun Dec 11, 2011 5:51 am Up
nice one Very Happy
PostPosted: Sun Dec 11, 2011 6:07 am Up
You shouldn't just jump in and turn the engine over on any car unless it has a carb and a mechanical fuel pump.
PostPosted: Sun Dec 11, 2011 6:14 am Up
i always let the fuel pump finished the self primping cycle before i start the engine
PostPosted: Sun Dec 11, 2011 6:25 am Up
Does the Peugeot not have a glow plug light on the dash that illuminates when the ignition is turned on, and then goes out when the plugs have heated up. Every diesel I have driven had one, but as said, once the engine is warm you don't need to wait for the glow plugs, otherwise white van man would be sat there all day.
PostPosted: Sun Dec 11, 2011 6:29 am Up
for any temperature over 0 degree the glow plug light will be off within 1/2 sec.
r1ch
PostPosted: Sun Dec 11, 2011 6:32 am Up
what does the glow plug light look like? the engine icon?
