Posted: Sun Dec 11, 2011 11:01 am |
my mother has a 1.1 206 and she was driving to work today and her aux belt snapped and lost it on the way home. now i do not have a haynes manual for the car.
so i was hoping i could get some pointers/tip or a diagram of which way the belt goes as i have nothing to go off.
any help would be appreciated and thank you in advance
I'm sure there is one in the how to section
Posted: Sun Dec 11, 2011 11:07 am |
Has it got air con?
If not there's a how to replace a cambelt guide i posted in the maintenance sub section, that should show you how to do it.
If it does its got an automatic tensioner that you use a 3/8" ratchet to hold the tensioner back against the spring while you remove the belt.
Posted: Sun Dec 11, 2011 11:08 am |
| richpowell91 wrote: |
Has it got air con?
If it does its got an automatic tensioner that you use a 3/8" ratchet to hold the tensioner back against the spring while you remove the belt. |
Cambelt and AUX belt are two TOTALLY different things
Posted: Sun Dec 11, 2011 11:12 am |
| Lee wrote: |
Has it got air con?
Cambelt and AUX belt are two TOTALLY different things |
Very true probably should have said that you need to remove the aux belt before you can remove the cambelt. The guide shows how to remove the aux belt before advancing to removing the cambelt.
Posted: Sun Dec 11, 2011 11:16 am |
For the OP's refference here is said guide:
206info.co.uk/Forums/v...29081.html
Your looking at only the 3rd photo on how to remove the aux belt, as i said if its got air con its different.
Genuine belt from a Peugeot / Citroen dealer, there cheap enough.
Need to either know the VIN number OR if the car has aircon fitted as there are a few choice of different length belts depending on the equipment fitted.
VIN number would be quickest & easiest.
Posted: Sun Dec 11, 2011 11:24 am |
Your looking at only the 3rd photo on how to remove the aux belt, as i said if its got air con its different. |
i did have a little search and found your guide. i should of said it has a/c. sorry
Posted: Sun Dec 11, 2011 11:28 am |
Choice of 3 different length belts for the TU1 206 with aircon fitted.
Really need the VIN number to pinpoint the correct one.
All use a automatic sprung loaded tensioner.
| IAmMcLovin wrote: |
i did have a little search and found your guide. i should of said it has a/c. sorry |
In that case it should have a automatic/dynamic tensioner.
www.peugeot206cc.co.uk...-p00k3.htm
Item 3.3 is related to the tensioner. Basically insert 3/8" ratchet into the square hole (7) and turn to remove tension on the belt. Remove belt then hold the tensioner back again so no tension is on the belt as you put it on then release the tensioner.
Just remember the routing of the belt.
Posted: Sun Dec 11, 2011 11:42 am |
| IAmMcLovin wrote: |
Just remember the routing of the belt. |
the belt snapped and has been lost while driving. so have no idea of the routing of the belt anyone wanna take a picture lol or have a diagram they can upload.
thank you
Posted: Sun Dec 11, 2011 11:54 am |
In that link i posted, section 2 - forth photo down shows the routing.
Posted: Sun Dec 11, 2011 3:41 pm |
okay thanks for the help mate i will let you know how i get on.
Posted: Sun Dec 11, 2011 7:41 pm |
Just out of curiosity how long do they usually last?
