Online Now [1419]:
Visitors: 1418
Today: 108865
Total: 151241830
Forums › The Car › 206 Talk › Spraying out doors.
Spraying out doors.
Forum Index › 206 Talk
rick-gti
PostPosted: Tue Dec 13, 2011 11:48 am Up
I plan on spraying from the side bump strips down on both sides. Would I be ok to do this outside in the temperature it is roughly outside now? I have some time off over xmas so want to try and do it then.
clio 197sport owner
PostPosted: Tue Dec 13, 2011 11:50 am Up
No, there's too much moisture in the air for a good finish.
Antknee
PostPosted: Tue Dec 13, 2011 11:55 am Up
its also better if the surface you're going to paint isnt cold
rick-gti
PostPosted: Tue Dec 13, 2011 12:04 pm Up
I was thinking that, would I be ok to prep and prime? Ive got a few rust spots on the sills thats all.
clio 197sport owner
ExoVyper
PostPosted: Tue Dec 13, 2011 12:15 pm Up
if you prep and prime now you'll just have to do it again after christmas when it's finally dried out Razz
might just be worth waiting pal
HDI90
PostPosted: Tue Dec 13, 2011 1:02 pm Up
i wouldnt mate , ive done it in the past and its come out milky due to it being damp
GTI 180
rick-gti
PostPosted: Wed Dec 14, 2011 2:56 am Up
i will leave it then until it warms up.
clio 197sport owner
Rob2859
PostPosted: Wed Dec 14, 2011 12:24 pm Up
If you put rattle cans in hot water for 10 min before you spray it works better too. In this cold the paint is just going to ripple I found that out last winter that was a pain in the a**e.
