Online Now [1250]:
Visitors: 1249
Today: 284713
Total: 151405947
Forums › The Car › 206 Problems › How to much to change a speedo?
hammer206
PostPosted: Sat Dec 17, 2011 8:29 am Up
Hi all
Basically a mate of mines been offered a good deal on a 98 206 however its speedo needs fixing, anyone got a rough idea of the cost?
Cheers
PostPosted: Sat Dec 17, 2011 8:41 am Up
hammer206 wrote:
Hi all
Cheers
Depends whats exactly wrong with it & what diagnostic tests have been carried out to pin point the fault.
Could be the cluster
Could be the sensor
Could be a broken wire
Have the drivers door on the safety catch & drive up to 10mph, if the interior light starts flashing it means the speed sensor & wiring are fine & you have a instrument cluster fault.
If the interior light doesnt flash on test then its a speed sensor / wiring issue.
hammer206
PostPosted: Sat Dec 17, 2011 9:58 am Up
Yeh it's a sensor / wire issue
PostPosted: Sat Dec 17, 2011 10:02 am Up
Wires can break at the big connector plug behind the passenger side wheel arch liner.
