Posted: Tue Nov 22, 2011 9:18 am |
How!?!?
| F**k Scene YAWN
Project GreenMachine: 206info.co.uk/Forums/v...rt=75.html | |
Posted: Tue Nov 22, 2011 9:22 am |
as in to replace air bag?
take glovebox out get your arm up there and have a feel for the little torx screws there's also one or two around airvent too. if thats what your on about anyway.
Posted: Tue Nov 22, 2011 9:57 am |
| BigGreenDave wrote: |
| How!?!? |
Try removing the screws & nuts is a pretty good start.
Posted: Tue Nov 22, 2011 9:59 am |
Take a pillow and push the seats right back haha it's painfull
| Image removed due to size
Team, ST
Team, Gti 138 track slag | |
Posted: Tue Nov 22, 2011 10:19 am |
Haynes manual identifies the screw locations - when I took mine out I removed glove-box, centre console and the panel at the end of the dashboard first for better access and to get some extra light in there - it's fiddly and you end up lying on your back in the footwell with a torch in your mouth
Posted: Tue Nov 22, 2011 10:46 am |
The airbag on the passenger side isnt a cover, its a whole airbag unit.
If thats what you meant.
If not sure its only about 5 screws and a plug you unclip
| WIP: Black 1.6 16v XSi
Beauté Noire | |
Posted: Tue Nov 22, 2011 11:16 am |
Undo the airbag connector and connect the terminals to a 9-14volt battery. That will remove it from it's casing
Posted: Tue Nov 22, 2011 11:20 am |
| Lee wrote: |
| Undo the airbag connector and connect the terminals to a 9-14volt battery. That will remove it from it's casing |
Multimeter set to resistance setting will give the same result
Posted: Tue Nov 22, 2011 11:44 am |
Pretty sure that the dash is wrecked if the passenger air bag does off. There isn't a seam around the cover so it will tear through it if it goes off.
If you are contemplating touching the airbag system, disconnect the battery and leave it for 15-20 mins to disarm itself.
Cant believe you told somebody to do that with out stating its f*****g dangerous! do not put and voltage on to the airbag connections!
If they got hurt because of stupid a**e comments like that...f*****g retards.
| This 206 IS going on a trackday despite it's every effort to stay at home in the garage! | |
Posted: Tue Nov 22, 2011 11:46 am |
Good thing about the 206 is the passenger airbag is just screwed / bolted on & easy / cheap to replace unlike a lot of cars where the whole dash needs replacing when the passenger airbag fires.
Posted: Tue Nov 22, 2011 12:19 pm |
| D4NTP wrote: |
If they got hurt because of stupid a**e comments like that...f*****g retards. |
They must be f*****g retards if they do it.
Posted: Tue Nov 22, 2011 12:58 pm |
Trade Rating: +59
| Lee wrote: |
| They must be f*****g retards if they do it. |
This.
| '98 Nile Blue 306 GTi 6
'04 Obsidian Black 206 GTi 138 | |
Posted: Tue Nov 22, 2011 2:23 pm |
| Lee wrote: |
| D4NTP wrote: |
It honestly wouldnt bother you if someone did what you said (however stupid you may think it is) and seriously hurt themselves?
Posted: Tue Nov 22, 2011 2:50 pm |
| D4NTP wrote: |
| Lee wrote: |
| D4NTP wrote: |
It honestly wouldnt bother you if someone did what you said (however stupid you may think it is) and seriously hurt themselves? |
Not really. Should always use common sense before doing anything.
