Online Now [915]:
Visitors: 914
Today: 235785
Total: 150825828
Forums › The Car › Request a how-to › Knight rider like lights
DCFC734
PostPosted: Sun Dec 25, 2011 7:46 am Reply with quote Up
Apologies if this is in the wrong section but please move if necessary.
I was thinking the other day adding some lights the knight rider car has on the front, the red lights that go side to side. Has anyone fitted soem of these lights and is it easy to do ?
206 owner
PostPosted: Sun Dec 25, 2011 8:29 am Reply with quote Up
Cant have them on when on the public road + they look s**te.
jimjam19927
PostPosted: Sun Dec 25, 2011 8:53 am Reply with quote Up
Haha so true but on a more useful note it's easy to do. Just mount a neon that has the function/effect of side to side movement and wire it in. Two wires 12v+ and an earth. You could take it from the battery and fit a switch. There is a gromit behind the glove box that allows wires to be passed through the bulk head. Search amp fitting or how to wire an amp/sub in. It will be under the how to section
Member: 685
I Over Use Smilies Razz
PostPosted: Sun Dec 25, 2011 9:31 am Reply with quote Up
Ive seen quite often a upper grille pop up on ebay which has this effect
DCFC734
PostPosted: Sun Dec 25, 2011 10:09 am Reply with quote Up
Thanks for the opinion, it wasn't definite i would fit some, was just an idea i had about easy mods i could o to the car,
206 owner
DCFC734
PostPosted: Sun Dec 25, 2011 10:10 am Reply with quote Up
Thanks jimjam, i did do a search but couldnt see anything but may have been what i searched for.
Merry xmas to you all
206 owner
Rob2859
PostPosted: Sun Dec 25, 2011 3:07 pm Reply with quote Up
I had the idea of using one as a 3rd brake light but I don't think the police would be too impressed.
PostPosted: Sun Dec 25, 2011 4:51 pm Reply with quote Up
It would be better if you fitted it so that it came on when you locked the car Wink
Rob2859
PostPosted: Sun Dec 25, 2011 5:05 pm Reply with quote Up
That is actually a very good idea. Although I have to use my key Very Happy
PostPosted: Sun Dec 25, 2011 5:11 pm Reply with quote Up
Use a relay so it came on when the door pins went down, and fit an ignition wire on the switch so that it didn't come on if you lock your doors when driving Wink
Rob2859
PostPosted: Sun Dec 25, 2011 5:36 pm Reply with quote Up
Nah will be easier just to bang it onto the interior light and get you to fix my remote locking Wink
PostPosted: Sun Dec 25, 2011 5:42 pm Reply with quote Up
Interior light uses a BSI earth, circuit gets earthed when you unlock/lock, via a capacitor
PostPosted: Sun Dec 25, 2011 5:43 pm Reply with quote Up
Just NO
Mike_XS
PostPosted: Mon Dec 26, 2011 4:37 am Reply with quote Up
I thought the 3rd brake light wasn't a legal requirement, so surely it wouldn't matter?
PostPosted: Mon Dec 26, 2011 4:43 am Reply with quote Up
Every car since the P reg has one
  Quick Reply
Username:
Message:
Quote the last message
