Online Now [1665]:
Visitors: 1664
Today: 161448
Total: 150759201
Forums › The Car › 206 Problems › cat faliure HELP
cat faliure HELP
tailhappy
PostPosted: Wed Dec 21, 2011 6:08 pm Up
car will take a while to start fires up on 3 or maybe 2 cylinders then cat faliure flashes up then car starts dying what can i do??
jamie bennett
PostPosted: Wed Dec 21, 2011 6:20 pm Up
well you need to get the code read first
sean.r.steward
PostPosted: Wed Dec 21, 2011 7:12 pm Up
might be sumthing simple like sparkplug r shot, maybe its frowing you emissions off
Rob2859
PostPosted: Wed Dec 21, 2011 8:37 pm Up
Make sure your 02 wires are not corroded. My second one was and my car ran on 2 cylinders.
tailhappy
PostPosted: Thu Dec 22, 2011 4:59 am Up
iv had the plesure of replacing the plugs and tryed unpluging lambda sensors only thing i think now is to take the cat off and clean it out
jamie bennett
tailhappy
PostPosted: Mon Jan 02, 2012 1:13 am Up
to anyone with the same probably it turns out my coil pack died and put strain on the injectors to pump more petrol in and now have to replace number 1 and 3 injector and lambda sensor ....... TO ANYONE WHO HAS AN XSI THIS "IS" YOUR probably AS THE GARAGE I TOOK IT TO HAVE HAD EXACTLY IDENTICAL IN THE LAST 6 YEARS ............
jamie bennett
