Latest: heikkisj
Overall: 17126
Online Now [384]:
Visitors: 383
Today: 27970
Total: 100360926
Forums › The Car › 206 Problems › 206 Gti 180 - Slow?
206 Gti 180 - Slow?
Go to page Previous  1, 2
crocdino
PostPosted: Tue Dec 27, 2011 8:54 am Up
I swapped the plugs in mine.. It had Denso ones in it for some reason - gapped at around 2mm!!
Put in the standard Bosch plugs (from the dealer) gapped correctly and it was like a new car to drive.
GTI 138 facelift - Runabout
335d M Sport - Cruiser
colganraz
PostPosted: Tue Dec 27, 2011 9:11 am Up
Cherry180 wrote:
So I took my partners Gti180 for a spin the other night and couldnt help but think 'it must have something up with it'
It feels flat as a turd, torqueless with no real fizz up the higher revs?
I myself have a Ph1 Clio 172, and it would utterly shame the 206 in a straight line (and the corners Wink )... Leading me to again think there's something wrong with the 206??
It doesnt have any running issues at all, no management lights etc... It just isnt packing as much of a punch as I would expect.
Do these suffer any blind problems? VVT Solenoid packed up or along those lines??
Cheers
172 is quicker in a straight line anyways, but not to the point of the 206 feeling slow and like garbage, maybe it needs a service including new plugs?
Former 206 XSi owner - Now 207 GT
www.206info.co.uk/Foru...56475.html
Bilco9
PostPosted: Tue Dec 27, 2011 10:23 am Up
Maybe you just need a new car. the 206 gti 180 were fast. when i had one everything beat me in straight line speed!!!
Goodbye 206 hello Evo x
Mattie-RS
PostPosted: Tue Dec 27, 2011 10:28 am Up
tell her she needs a Clio Wink
Bilco9
PostPosted: Tue Dec 27, 2011 10:40 am Up
I wish i had gone for a clio my 206 was always breaking! It cost me £1000!!!!
PostPosted: Tue Dec 27, 2011 11:23 am Up
never found mine slow at all compared to similarly powered hatches but straight lines not what a hot hatch is about its all about the twisty b-roads and with a good suspension set-up the 180 is awesome
Schumi
PostPosted: Tue Dec 27, 2011 2:00 pm Up
Which gap is correct.
2005 206 RC RED
PostPosted: Tue Dec 27, 2011 2:11 pm Up
Denso are part of the Toyota group Wink
ramigojag
PostPosted: Wed Dec 28, 2011 3:31 am Up
I seem to remember reading on auto data should be 0.9mm gap on the 180 engine
could be wrong though
Cherry180
PostPosted: Wed Dec 28, 2011 9:21 am Up
Update
Ran a diag on the car to find the following:
Intermittent fault. Variable timing electrovalve Locked at the lower stop.
and
Intermittent fault. Variable timing electrovalve Locked at the upper stop.
Thoughts?
2004 Peugeot 206 Gti 180\r\n2001 Ph1 Clio 172
PostPosted: Wed Dec 28, 2011 9:22 am Up
Cherry180 wrote:
Update
and
Thoughts?
First clean the VVT solenoid, if that doesnt cure it then replace it, there cheap enough.
Peugeot / Citroen part number 1920 GR SOLENOID VALVE £78.65 including the VAT should be the one.
colganraz
PostPosted: Thu Dec 29, 2011 8:08 am Up
a) Everything you raced was turbo powered
b) you cant drive fast in a straight line
c) there was something wrong with your 180
Cherry180
PostPosted: Fri Dec 30, 2011 4:42 am Up
MrBSI wrote:
Cherry180 wrote:
Update
and
Thoughts?
I can get it a tad cheaper (£60.56 Inc Vat) so I'm just going to get a new one instead of faffin about with the original.
See how it goes Smile
yokel
PostPosted: Sun Feb 12, 2012 4:45 am Up
Did you manage to sort this issue out with the electrovalve? Recently had similar performance issues, pug diag came up with intermittant electrovalue they reset the system but it feels lagging again, need to take it back really and get it checked again.
Regards
Page 2 of 2
