Latest: sparrowdclxvi
Overall: 17139
Online Now [116]:
Visitors: 114
Members: 1
Today: 10996
Total: 113423740
Forums › The Car › 206 Problems › brake pedal keeps going stiff??
leeb130
PostPosted: Wed Dec 28, 2011 6:23 pm Up
hey everyone,
problem im having recently is when braking the pedal becomes stiff, and brakes arent as effective, this only happens occasionally. If i release the pedal then press again its soft again Confused seems to be getting more frequent.
had a search but couldnt find a definitive answer
cars a 1.6 xs 2000
Any idea what could be causing this?
thanks in advance
lee
Leeb130
Rob2859
PostPosted: Wed Dec 28, 2011 6:31 pm Up
It sounds like a loss of vacuum pressure. Not sure if an air-lock could cause it.
dumdum0910
PostPosted: Thu Dec 29, 2011 12:29 am Up
i get this now and then aswell. still havent found the problem . i have no airleaks and the master cylider is fine.
dumdum0910
Deckchair5
PostPosted: Thu Dec 29, 2011 3:34 am Up
Sounds like brake servo
When you turn the engine off then pump the brake pedal. For the first few pumps it should feel normal and then there will be no vacuum remaining and the pedal will go solid, probably action the brakes higher up. If this is what you feel/ experience when the fault occurs then you know what you're looking for eg loss of vacuum or servo fault
I'd check for damage or weakness in the side walls in engine to servo vacuum pipe as it can crush with the vacuum. Servo has plastic check valve so I'd check that out. After that then it's checking with a vacuum pump and gauge to see if it can hold vacuum
Some diesels have their own vacuum pump
