Latest: eionpeu
Overall: 17120
Online Now [52]:
Visitors: 51
Today: 14481
Total: 97156228
Forums › The Car › 206 Problems › fog light/break light shown on dashboard when headlights on
fraggle8
PostPosted: Thu Dec 29, 2011 12:34 pm Up
Hi
I have a Peugeot 206 1.4 hdi 2001. Whilst driving a long a few weeks ago the fog light and brake warning light displayed on the dashboard. After a few checks we found that the 2 lights only display when the headlights are turned on. if the lights are off or on side lights or full beam they go out. The brake fluid is fine and a mechanic checked the brakes and they are also fine. It has also been hooked up to a machine which showed no problems. Itaqppears to be some kind of wiring fault does anyone have any suggestions on what the problem could be or experienced similar?
PostPosted: Thu Dec 29, 2011 12:47 pm Up
Does fog light come on?
fraggle8
PostPosted: Thu Dec 29, 2011 12:51 pm Up
no the fog light stays off. if i turn the fog light on the light on the display gets slightly brighter! i have checked all the lights and they are all working as normal
PostPosted: Thu Dec 29, 2011 12:52 pm Up
Earthing fault or a loose connection then at the stalk/com and cluster
