Posted: Thu Dec 29, 2011 10:20 am |
Hi guys, I'm new at this forum, and I registered to see what you guys think about my problem.
Anyway, I own 1.4i 75hp 206, produced in 2006.
Problem is, when I start the car, I hit the gas pedal and instead of making revs go higher, engine first makes them lower! So it goes like this: I start the engine, wait for a few seconds, then just for a brief moment I hit the gas and release it, and revs first go down (for, say, 150rpm) and THEN go up without problem. In some cases, if I hit the gas for too long, engine goes off! (when engine's cold)
Besides that, engine's responding too late in casual driving.. It's like it is hesitating.
My regular garage-man told me that perhaps it could be lambda sensor... Other than that, he has no clue. (no problems found on diagnostics whatsoever).
And I have found out that cleaning of stepper motor, throttle body and MAP sensor may help !!?? And maybe, ECU update..?
So, what do you guys think of it ?
Posted: Thu Dec 29, 2011 11:02 am |
Does your engine have an electric throttle body? If so, you will not have a idle control valve
Posted: Thu Dec 29, 2011 11:21 am |
I'm not quite sure what makes throttle body electric, but I have "drive by wire" if that's what you mean...
Posted: Thu Dec 29, 2011 11:26 am |
marko.rebric wrote: |
I'm not quite sure what makes throttle body electric, but I have "drive by wire" if that's what you mean... |
Then you have an electronic throttle body
Posted: Thu Dec 29, 2011 11:28 am |
ECU needs updating.
Posted: Thu Dec 29, 2011 11:32 am |
Posted: Thu Dec 29, 2011 11:40 am |
A software bug in the engine ecu.
Peugeot main dealer time & get the software updated
Posted: Thu Dec 29, 2011 12:11 pm |
A mate of mine had a Clio with a similar issue. It had an electronic throttle and would only rev down until it stalled. Cable all the way.
Posted: Thu Dec 29, 2011 12:16 pm |
Nothing wrong with fly by wire throttles if the software is written correctly.
Posted: Thu Dec 29, 2011 12:22 pm |
Chances are cable is not going to fail though and its more responsive from what I have heard. Also its harder to identify a noise when you can't adjust the throttle from the engine bay.
Posted: Thu Dec 29, 2011 5:08 pm |
So, the bottom line is ECU update...? But cleaning other things I mentioned would do no harm ?
Posted: Thu Dec 29, 2011 5:46 pm |
Yes, I had a similar problem, visit to main dealer for an update and it was solved
