Latest: eionpeu
Overall: 17120
Online Now [62]:
Visitors: 61
Today: 1861
Total: 97266047
Forums › The Car › 206 Problems › H4 Angels full beam don't work on H7 car
kurosagi01
PostPosted: Sun Jan 08, 2012 3:18 pm Up
Hello people,so i have a H7 04 206 which had crystal headlights.
I've had black angels for awhile now and their h4,i didn't have this problem until i changed my main beam to phillips xtremevision,now my passenger side the main+full beam all works perfectly fine with the h7 plugged into the h4-h7 converter provided with the h4 angels when i purchased it.
Both lights has the relay and and converter.
But i can't seem to get the driver side to work on the converter connected to the h7 cable on my car,it worked before i switched bulbs,i did connect the pre attached angels cable to its own converter it got the main beam to work but not the full beam.
Anyone know what the reason might be? This only happened when i switched the main beam bulbs with the phillips,the passenger side works 100% but driver side doesn't.
The side beam works perfectly fine as i can fit my original h7 ones into the side beam slot. Just the full beam is issue for me on driver side.
PostPosted: Sun Jan 08, 2012 3:43 pm Up
i would check fuses 1st may have blown one. or even the bulb it self.
kurosagi01
PostPosted: Sun Jan 08, 2012 3:48 pm Up
Fuses may have blown but which one blown i'm not sure i'm no expert with these stuff,as for bulbs they both work.
When i plug the h7 cable into the converter the main bull don't work but the full beam does and passenger side both main+full glows apart from drivers main beam.
The main beam would work if i plug the h4 main beam cable on angels into the converter but the full doesn't.
