Latest: SA01
Overall: 17138
Online Now [123]:
Visitors: 122
Today: 36056
Total: 112205930
Forums › The Car › 206 Problems › Sticking tappet like noise when cold.....am I right?
D4NTP
PostPosted: Sun Jan 08, 2012 4:37 pm Up
Started the 206 up after it has been stood for a good few days out in the cold and it sounded like a sticking tappet, took it for a drive and the tapping noise increased with revs and seemed, either not there or much quieter when i lifted off (no sound deadening so its hard to tell which).
Once the engine oil got up to around 60-70 degrees it went off all together.
Any ideas?
The oil and filter were done about 50 miles ago and is the same 10w60 millers I used last year when it was properly cold, with no problems.
PostPosted: Sun Jan 08, 2012 4:43 pm Up
well, probably too thick for winter anyway
D4NTP
PostPosted: Sun Jan 08, 2012 5:10 pm Up
Yeah, did think that but as its usually only driven on trackdays it doesn't get driven short distances cold, but like I said, it was fine last year.
Tried searching for other possibilities but only came up with a sticky tappet or dodgy tensioner.
PostPosted: Sun Jan 08, 2012 5:20 pm Up
i doubt is tensioner.
well, tappet will wear out over time so i am not surprise last yr was fine
why running 10w60 btw? it shear like s*** according to most scooby driver experiences
D4NTP
PostPosted: Sun Jan 08, 2012 5:35 pm Up
I'm running it due to the temps on the trackday mainly. My theory being if its sat near the red most of the time a 10w60 will maintain its viscosity better than a 40 and give it a bit more of a chance, particulary with the engine been worn already. It seems to keep the temperature down aswell.
My Cuz had a scooby and it wouldnt matter what oil you put in it, his blew up so many times it wasn't funny.
That said I wouldnt trust a scooby driver if they told me it was Sunday.
PostPosted: Sun Jan 08, 2012 5:50 pm Up
this is so true Laughing Laughing
or get yourself one of these?
www.wolverineheater.com/
D4NTP
PostPosted: Sun Jan 08, 2012 6:05 pm Up
A little excessive...... Although there should be one in the coolant system so the heater is nice and warm straight away
Mattie-RS
PostPosted: Sun Jan 08, 2012 6:08 pm Up
you need a oil cooler Smile
PostPosted: Sun Jan 08, 2012 6:11 pm Up
did you not remember imjeeve's 180gti accident with the mocal oil cooler? Laughing Laughing
Mattie-RS
PostPosted: Sun Jan 08, 2012 6:21 pm Up
no, what happened?
D4NTP
PostPosted: Sun Jan 08, 2012 6:23 pm Up
Never gets into the red, even with the Cadwell endurance run, so, untill this tappet incident I was planning on going without.
PostPosted: Sun Jan 08, 2012 6:30 pm Up
Mattie-RS wrote:
no, what happened?
the oil pipe going into the cooler snap during the event Laughing
new engine after that
Mattie-RS
PostPosted: Sun Jan 08, 2012 6:45 pm Up
Ouch!!
i was just thinking of keeping it warm but not too warm, cooler with a thermostat will keep it at a good temperature
i dont have a oil temp gauge, not sure what temps i am running on track
