Posted: Sun Jan 08, 2012 7:58 pm |
It's fine when lights off but when I put my lights on I cannot see display unless it is pitch black outside, if it's just getting low light outside so I turn on my side lights the display is so dim I can't read it.
Any ideas?
Posted: Sun Jan 08, 2012 8:56 pm |
if im right in thinking all 206's does this
Posted: Mon Jan 09, 2012 3:49 am |
All 206s do dim these lights when the lights are on however this does seem a bit extreme! You haven't changed the bulbs behind the displays or anything have you?
| Tivoli LX 1.1
Black GTI 180
White VXR Burg | |
Posted: Mon Jan 09, 2012 4:09 am |
Either a bulb(s) has gone or you need to adjust the brightness using the buttons on the instrument cluster, this procedure is in the owners handbook or somewhere on here.
| An Ex '03 1.4 GLX driver, German technology all the way now. | |
Posted: Mon Jan 09, 2012 10:32 am |
gixxerkev wrote: |
Either a bulb(s) has gone or you need to adjust the brightness using the buttons on the instrument cluster, this procedure is in the owners handbook or somewhere on here. |
Not on the OP's car, his is non plexed so its the dimmer wheel next to headlamp leveler
Posted: Mon Jan 09, 2012 10:36 am |
MrBSI wrote: |
gixxerkev wrote: |
Not on the OP's car, his is non plexed so its the dimmer wheel next to headlamp leveler |
It's on full but still can't read it unless completely dark outside
Posted: Mon Jan 09, 2012 10:41 am |
m4tth3w wrote: |
MrBSI wrote: |
gixxerkev wrote: |
It's on full but still can't read it unless completely dark outside |
Is the dimmer wheel working correctly on the rest of the dash / instrument cluster backlights?
Posted: Mon Jan 09, 2012 3:58 pm |
It only dims the instrument speedo and surround.
It doesn't dim or brighten the radio display or climate control
Posted: Mon Jan 09, 2012 4:00 pm |
Doesn't do it on mine either. Put it down to poor design.
