Latest: ArtistKS
Overall: 17145
Online Now [58]:
Visitors: 57
Today: 12323
Total: 115912324
Forums › The Car › 206 Problems › gear stuck shaking/vibrating under load
simon_p
PostPosted: Wed Jan 11, 2012 3:14 pm Up
Hi all,
Car is a Peugeot 206cc 1.6 16v. Between 30 to 55 the gear stick vibrates like hell, can also feel it through the floor pan and it rattles CDs etc in the door pockets etc. Can't feel it through the steering wheel and it's not wheel balance issues as its happened on two sets of wheels. It's had a new gear box mount and drive shaft but is still just as bad. The remaining old drive shaft is fine, as is the bearing on the long shaft. Engine wise there isnt much play in it, nothing I'd call excessive, but looking at the lower engine mount it has got loads of little cracks in the rubber, and one fairly large one.
the gear knob kind of shakes front to back.
si
Peugeot 206cc SPL build
2011 - 2 vibe 12" spaces, 38hz ported box, 2.5k Ground zero Nuclear mono - 141.2db @ 38hz
2012 - GZ Nuclear 12"s, 33hz box, 2 x 2.5k GZ Nuclear monos, 8" GZ comp mids, 4" GZ tweeters - 144.0db @40hz off 1500wrms
build thread -http://www.206info.co.uk/Forums/viewtopic/p=486554.html#4865540
simon_p
PostPosted: Fri Jan 13, 2012 1:53 am Up
Anyone?
D4NTP
PostPosted: Fri Jan 13, 2012 3:01 am Up
Exhaust catching on a gear linkage or engine mount?
PostPosted: Fri Jan 13, 2012 3:30 am Up
Of the rubbers all cracked it's sure sign it probably past it, I would change that next if it was me.
simon_p
PostPosted: Fri Jan 13, 2012 3:18 pm Up
Exhausts not catching anything. I'd have thought if it was it would only resonate rather than cause a shake. Plus gear linkages and mounts aren't near the exhaust.
That was my thought about the mount, it's just the fact the engine "seems" solid when trying to rock it.
