Online Now [76]:
Visitors: 75
Today: 16430
Total: 116703214
Forums › The Car › 206 Problems › Heater Blower Not Working
lomax1231
PostPosted: Thu Jan 12, 2012 9:39 am Up
hi,
my sister has a 206 Quick Silver, and the blowers has stop working, i had a look at it the other day and found that there was 12v supply to the blower and the resistor pack look fine and all the connector are ok, so i ordered a replacement blower motor but they are still not working, i did find that the air con was not switching on, the motor should work as there 12v going to it, would appreciate any help or if any one else has had similar problems, thanks
Peugeot 206 Quick Silver
Andrew
PostPosted: Thu Jan 12, 2012 9:52 am Up
Might be a long shot but when was the last time the cabin filter was changed?
My 206 thread
www.detailedbyandrew.com
lomax1231
PostPosted: Thu Jan 12, 2012 1:04 pm Up
Thank for the quick reply, she has not replace the filter, so will check that out. Thanks
Deckchair5
PostPosted: Thu Jan 12, 2012 1:11 pm Up
If you have 12v going to the motor and the motor is fine (because you've changed that) then you have an earth fault from the heater blower to earth. Would have been worth checking the earth before changing the motor but that's hindsight for you, always arrives straight after you really needed it
Set a mulitmeter on resistance and check for near zero between the heater connector earth and some shiny metal part on the engine
PostPosted: Thu Jan 12, 2012 1:13 pm Up
Blocked pollen filters help kill the blower motor Laughing
Done mine last month during the service, it had only been in a year & came out black Shocked
Andrew
Is it not switching on all together, or making loads of noise but no air coming through?
My 206 thread
PostPosted: Thu Jan 12, 2012 1:17 pm Up
Looks can be deceptive Wink
Rob2859
PostPosted: Thu Jan 12, 2012 1:56 pm Up
Mine is faulty somewhere. If I fiddle the big plug inside the dash up behind the glovebox it comes on after a while. I don't fancy changing it if I don't have to because its part of a big 3 plug loom and each plug is very difficult to get to.
